E Brake Light On But Not Pulled
Old Oct 23, 2014 | 09:43 AM
BryceJayhawk's Avatar
For some odd reason my Maxima's E Brake light is on, but its not pulled. What might be caused by this? Is this some sort of code? Can i get it fixed? Its became very annoying.
-BryceJayhawk
Old Oct 23, 2014 | 09:48 AM
-BryceJayhawk
Check your brake fluid. It could be low.
See pages 2-8 and 2-9 of your owner's manual for reference. That light serves double duty.
Old Oct 23, 2014 | 10:05 AM
When i bought the car it didn't come with a manual or i'll definitely would have checked that. But yes ill check that tonight.
Old Oct 23, 2014 | 11:39 AM
IMO, everyone should have an Owner's Manual; and have read it. Pick one up for peanuts on Ebay.
Old Oct 23, 2014 | 11:54 AM
JoshG's Avatar
Lucky when i bought mine, it already came with owner's manual. it is helpful at times.
Old Oct 23, 2014 | 12:21 PM
max-nutcase's Avatar
-BryceJayhawk
im sure there must be a switch under the lever ...most cars have em there anyway....
Old Oct 23, 2014 | 03:46 PM
DennisMik's Avatar
I doubt that the parking brake lever or switch is the problem. I've never heard of one needing adjustment. The problem is most likely low brake fluid.
Old Oct 23, 2014 | 05:01 PM
cornholio's Avatar
mine came on in my 5th gen, it was because the fluid was low
Old Oct 23, 2014 | 05:06 PM
chrome91's Avatar
either
-brake fluid level is low from a leak or needing new brakes
-the sensor that detects the E-brake being on is wonking out
-the light sometimes comes on in cold weather but thats probably the sensor wonking out again
Old Oct 23, 2014 | 06:29 PM
Originally Posted by chrome91
either
Thanks guys. Appreciate the help!
Old Oct 23, 2014 | 07:45 PM
Well, was it indeed the brake fluid?
Old Oct 24, 2014 | 09:12 AM
DennisMik's Avatar
either
This isn't always true. This could also be low brake fluid. Cold weather causes the brake fluid to contract. If the brake fluid level is getting close to causing the warning light, then the cold fluid will trigger the light. If the light is on when you start the car and it goes out after the car has been driven for a while, that's your clue for low brake fluid as the engine heat warms up the brake fluid and it expands.
Old Oct 24, 2014 | 05:40 PM
chrome91's Avatar
thats why i also said it could be the fluid level, my Hardbody in the cold the E-brake light would come on. i would just push the E-brake down another 2-3mm and it would go off
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
