After a year..i have decided to get back on my dek turbo swap
Old Nov 9, 2014 | 12:03 PM
max1008's Avatar
Hey guys finally got the car running smoothly but my slim fan arent coming on..here's how I wired it:
Blue and green to harness is tied to blue on slim fans. Black wire is to black wire. Butt ended the yellow.
Did I do this right? Cause they arent cutting on
Old Nov 9, 2014 | 01:24 PM
maxgtr2000's Avatar
KH3 by popular demand
Are you giving the fans time to come on? Check your grounds and fuses. There are also the rad. fan relays.
Old Nov 9, 2014 | 03:25 PM
max1008's Avatar
Well the can ran idle for 30 minutes and the temp hit half way..thought they would have cut on...
Old Nov 9, 2014 | 06:57 PM
chrome91's Avatar
did you rev it at all? only idling for 30 minutes might not have been long enough for the fans to come on especially if its cold outside
Old Nov 9, 2014 | 07:39 PM
Hook up a diagnostic tool or a scangauge etc and monitor your actual temps.
Fans will kick on LOW at 203F and HIGH at 221F.
If you turn on your AC, the fans should both instantly kick on.
Old Nov 9, 2014 | 07:58 PM
jholley's Avatar
Those are very close to the temps I measured after replacing a defective thermostat today. I used a scangauge to verify what temp the aftermarket autozone thermostat opened at.
Thermostat opened: 180f
LOW fan speed: 202f
HIGH fan speed: 220f
Those are the temps of using nearly 100% distilled water. I later backflushed the coolant system, ran distilled water 3 more times, then added Nissan green coolant.
Old Nov 10, 2014 | 03:45 AM
max1008's Avatar
Ill check the temps..but with fan on they didnt cut on. Is that wiring correct? Yes iactually dove it around the neighborhood to get the temps to rise as well.
Old Nov 10, 2014 | 01:24 PM
Hard to say without seeing the wiring diagram instructions for your slim fans.
For reference, you'll want to look at pages EC-430 through EC-433 of the FSM for the wiring schematic of the OEM fans.
Old Nov 10, 2014 | 02:43 PM
Fakie J Farkerton's Avatar
Copy/paste from my phone notes:
Radiator fans wiring
pin 1 = white/black stripe - low speed positive connection
pin 2 = white/blue stripe - high speed positive connection
pin 3 = white/red stripe - low speed negative connection (ground)
pin 4 = solid black - high speed negative connection (ground)
YOU WANT THE HIGH SPEED SIDE.
JRod28
Dec 29, 2023 09:56 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
Finkle
Sep 27, 2015 09:53 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
