No front blinkers. 97 maxima
Old Nov 29, 2014 | 08:24 PM
N199A's Avatar
1997 NISSAN MAX, ALL 35W HID AC 6000K. (9004)(H3) NOW NO FRONT BLINKERS. Tester shows a load , alters current but eventually drops to 0. no lights from the front directionals (1156) at all. The rears blink fast, and hazards flash in back only. Also replaced the rotted radiator support, but had lights after that..seems after the xenon conversion car got angry. Any help? also replaced flasher combination switch below steering column, near right lower left side, still same.
thnxz in advanced
Old Nov 30, 2014 | 02:44 AM
bumpypickle's Avatar
have you checked your fuses?
Old Nov 30, 2014 | 03:14 PM
DennisMik's Avatar
Remove both front flasher bulbs and do a continuity check on the wall of the lamp socket to ground.
Old Nov 30, 2014 | 03:37 PM
N199A's Avatar
All fuses ok, will try the continuity test, do i use a body ground as the neg?
Old Nov 30, 2014 | 05:12 PM
maxfever1987's Avatar
U might have a bad relay, it's by the steering wheel just below it to ur right
Black in color I believe, ill double check for you
Old Dec 1, 2014 | 08:08 PM
N199A's Avatar
Thnxz guys, was a bad multifunction flasher relay. I enclosed some photos to help others.
http://boredmder.com/pics/maxima.org...on-flasher.JPG
http://thumbs1.ebaystatic.com/d/l225...RvpItIcF7Q.jpg
Old Dec 2, 2014 | 07:01 AM
Fakie J Farkerton's Avatar
Glad you fixed it.
I would have suggested it, but you literally said you had replaced it in your first post.
Old Dec 3, 2014 | 06:08 PM
N199A's Avatar
I did replace it the first time...but A friend had the bright idea that possibly a junk yard one is best...AFTER THE FACT. I was told he got it new...lol LIARS! Trip to the dealer solved the problem with, get ready, a NEW relay. BEWARE OF FRIENDS!
MAXSE5SPD
Aug 23, 2015 12:06 PM
wingsfan24
Aug 15, 2015 07:35 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
BassAddictJ
Aug 4, 2015 11:38 AM
