Are Springs and Coilovers the same thing?
Re: Are Springs and Coilovers the same thing?
Originally posted by Pappa Grande
I just read the sticky for changing the suspension. If I get in on the GC group buy can I (the home mechanic) install coilovers the same way as springs?
Thanks.
Thanks.
Yes you can install them yourself.
Re: Re: Re: Are Springs and Coilovers the same thing?
adjustable coilovers have a sleeve that moves up/down, thus, allowing you to change the ride height to a certain extent: http://www.eatricezone.com/images2/gc01.jpg
normal spring/shock combos have a spring perch that is not adjustable, so the ride height is based upon the spring length and spring perch location: http://www.eatricezone.com/images2/53059.jpg
side by side (300ZX parts): http://www.eatricezone.com/images2/gc02.jpg
Ground Control coilovers = Sleeve type. They are just regular lowering springs with an adjustable perch so you have height adjustability. They are NOT true coilovers and you still need a set of performance struts. These are relatively cheap since they are just "springs" and you will need your own set of struts to go with them.
Coilovers = True coilover. These are performance springs paired with a performance strut from the same company. These will run you atleast 750 a set (TEIN basics). Normally they have full height adjustability and the more expensive ones also have full adjustable damping (strut stiffness).
Or you can get any normal spring + strut combination separately.
For simplicity reasons, you can just think of struts and shocks as being the same thing since they basically perform the same function (absorb the spring's bounce after compression), although they are slightly different in how they are designed.
Be warned that the Ground Control "coilovers" (they're just adjustable spring preches) are crappy in terms of both ride, noise, and build quality.
You're much better off getting a set of springs that will lower the car to the height you want it, or better yet go for true adjustable coilovers as they're just a little more $ than the lowering springs and struts, but the performance is light years ahead.
Originally Posted by tekneekzz
hey with coilovers do you need to buy anything else.. i heard that if you get coilvoers or springs you'll have to upgrade some other parts.. or it will wear out quick or something..
man im too cheap/poor for that *sigh*..
The only possible exception is the Tokico HP kit ($400, give or take), but that kit uses Tokico's OEM replacement struts. They probably won't blow out that fast with those springs, but the ride will still be pretty harsh (just cuz the struts can barely handle the springs).
BTW, those eBay "coilovers" are inconceivably bad. The price says it all.
imported_Nismo_max
Feb 17, 2016 03:39 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
