Cat Back Question
Old Jan 24, 2002 | 01:53 PM
gryps's Avatar
Cat Back Question
is the perfomance gain from installing a cat back system worth the $$?
from what i read in the previous posts it doesn't seem to do much except kill low end torque.
or am i wrong?
Old Jan 24, 2002 | 01:55 PM
Viscous's Avatar
try searching first.
to some it up, the loss of low end torque is worth the gain in mid and high end.
enough said
Old Jan 24, 2002 | 01:57 PM
Viscous's Avatar
enough said
lol too some it up.. i'm smokin crack at work.. too tired... TO SUM IT UP i meant.
Old Jan 24, 2002 | 01:58 PM
SuDZ's Avatar
How much slower does it really make you off the line anyhow? Is it noticeable?
SuDZ
Old Jan 24, 2002 | 02:18 PM
Viscous's Avatar
SuDZ
yeah it lags noticeably. and then wham, after 3.5k rpm you feel the puullll like crazy, and once you are in second, rpms stay high enough to keep pulling. So they only real loss is about 0-20mph.
Old Jan 24, 2002 | 02:46 PM
nigelcmf's Avatar
Y pipe does the same thing I think. You lose low end cos of lack of backpressure, you gain mid to high end cos the flow is better.
I felt a slight difference on my Y pipe on the low end.
The whole deal just makes you want to run at higher rpms!
Old Jan 24, 2002 | 02:56 PM
Viscous's Avatar
Imagine this.. having all of the low end losing mods. Intake, ypipe, 3" piping, RT Cat, and a dual exhaust! Your car will be so slow off the line and then it'll finallt catch on and zip through the gears. 60ft times would suck, but 1/4 mi will be decent, and top end power would be nice.
Old Jan 24, 2002 | 03:13 PM
nigelcmf's Avatar
You'd think they'd make a progressive valve controlled Y pipe tthat closes when pressure is low, restricting flow on the low end. As the pressure builds up, it would open up to breathe better ... why hasn't anyone done that yet? Variable intake runners are based on a similar principle ...why not exhaust?
Old Jan 24, 2002 | 04:01 PM
95emeraldgxe's Avatar
as long as the piping is between 2.25-2.5 inches, you really shouldnt have to worry about losing power..... anything bigger or smaller will screw you up
JRod28
Dec 29, 2023 09:56 PM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
sonic7
Aug 20, 2015 12:23 PM
MikesChevelle
Aug 19, 2015 07:19 AM
09maxshawn11
Aug 14, 2015 10:07 PM
