transmission problem?
Old Jan 24, 2002 | 03:28 PM
96gxe's Avatar
I just noticed today when I got in my car and shifted out of park to R that there was a scraching(metal aginst meatl) sound comeing from I am gussing the transmission. After shifiting through the gears somemore while at a stop I also noticed the hard shifts were strong enough to pull the car a few degres to the left and right. Got my girl to run through the gears while I looked under the hood and I noticed the engine moveing from left to right very harshly! Also the RPM is pulled down to about 2 0r 3 hundred during shifts. I drive an auto. I also put in a transmission cooler about a month ago.It dose not shift as hard when the car is warmed up but scraching noise is still there. Its only 60 out side so I don't think the cooler is keeping it to cold.
IS MY TRANSMISSION DIEING? OR DO I JUST NEED TO REPLACE SOME MOUNT BUSHINGS?
Old Jan 24, 2002 | 03:32 PM
Eric L.'s Avatar
If your engine is shifting back and forth excessively, I would check the motor mounts or the transmission mounting points.
Old Jan 24, 2002 | 03:37 PM
96gxe's Avatar
Is there a proper way to check? I know there are 4 on the engine but were do I look for the transmission?
Old Jan 24, 2002 | 03:46 PM
96gxe's Avatar
And what about the scratching????
Old Jan 24, 2002 | 04:54 PM
93_MaxSpeedMark's Avatar
If you've got a warranty, convince them you need a new tranny and get a 5 spd.
Old Jan 24, 2002 | 04:58 PM
96gxe's Avatar
About 2 hit 100k
Old Jan 24, 2002 | 05:40 PM
nigelcmf's Avatar
Time for a 5sp tranny swap!
Old Jan 24, 2002 | 05:50 PM
96gxe's Avatar
Come on guys I need answers.
Old Jan 24, 2002 | 05:58 PM
sbslacker's Avatar
Eric L. just gave you one. You really need to stop the engine from moving like that when you engage the transmission. Take it to a mechanic or get a manual (Haynes, FSM or whatever) and look at the mounting points. Make sure they are secure.
Old Jan 24, 2002 | 06:12 PM
nigelcmf's Avatar
Hehe....sorry, thought you had your answer above! Check the mounts. Engine movement like that is not right. I have not heard of this problem before though! Has the tranny or engine been out before?
Old Jan 24, 2002 | 06:14 PM
96gxe's Avatar
Thanks thats what I will do. But do you think there is any thing wrong with the transmission it self.
Old Jan 24, 2002 | 06:17 PM
96gxe's Avatar
No.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
