95' maxima - cut shut off after 10 minutes
Old Jun 12, 2015 | 06:47 PM
jes0355's Avatar
I have a 1995 maxima and it run fine for about 10 min. and then just shuts down
I have no idea what it could be. new fuel pump, new coils and plugs and new fuel filter. Anyone have an idea?
Old Jun 12, 2015 | 07:15 PM
Slamrod's Avatar
Any codes? Is the car overheating?
Old Jun 12, 2015 | 10:46 PM
^ Check your coolant level. I've personally seen Maximas shut off when really low on coolant. Probably due to the Engine Coolant Temperature Sensor (ECTS) going haywire for some reason.
Check that the ECTS has the proper readings using a multimeter
Could be the Fuel Pressure Regulator (FPR) too, but unlikely. But don't rule it out, as I've personally had a bad FPR shut my car off while driving.
Check/replace the MAF with an OEM MAF.
Check/replace ignition switch
Old Jun 14, 2015 | 07:03 PM
maxinout93's Avatar
check coolant temp sensor,
Hondarydr
Dec 30, 2024 06:15 PM
kjlouis
Nov 24, 2018 06:09 AM
lux97Max
19
Aug 27, 2015 07:48 PM
erniel
Aug 8, 2015 09:32 AM
