1997 Maxima
Old Jun 15, 2015 | 04:34 PM
bassmann's Avatar
1997 Maxima
Hi, the car has codes p0105 and p1105. I tested both sensors and they are good. Hoses and harness connections are also good. The car is running fine. Has anyone had this problem? Please help if you can.
Old Jun 16, 2015 | 02:54 PM
DennisMik's Avatar
Did you check the sensors by following the FSM? Codes don't show up for no reason, so something is not correct.
The P1105 (MAP/BARO sensor) gets confused with the sensors right next to it, so there is the possibility of you checking the wrong one. The P0105 (Absolute Pressure sensor) doesn't have this identity problem.
But these 2 sensors are interlinked. The vacuum for the absolute pressure sensor goes through/comes from the MAP BARO sensor (or visca versa).
Old Jun 17, 2015 | 01:18 PM
bassmann's Avatar
thanks, where can I find the FSM?
Old Jun 17, 2015 | 01:44 PM
PH98I30's Avatar
Some members like Fakie Farkerton and Asand1 have FSM links
Old Jun 17, 2015 | 01:57 PM
PH98I30's Avatar
The Wizard has an FSM link.
Old Jun 17, 2015 | 03:00 PM
DennisMik's Avatar
http://boredmder.com/FSMs/Nissan/Maxima/1997/
or
http://www.nicoclub.com/FSM/Maxima/1997/
Old Jun 17, 2015 | 03:13 PM
bassmann's Avatar
Thank you.
Goffery2uned
Aug 21, 2015 09:50 PM
Samedi
Aug 13, 2015 04:05 PM
jchronis2552
Aug 13, 2015 07:48 AM
