Turn signal wire
Old Jul 10, 2015 | 09:32 PM
Kevinmax's Avatar
Turn signal wire
Can anyone tell me what type of plug this is or how to remove the wires from it? One of the wires is broken just behind the plug and I need to rewire it. Do I need any special tools to remove the wires as they are right now?
Old Jul 10, 2015 | 10:19 PM
If you're in a hurry, go to your local Radio Shack and ask for terminal de-pinning tool kit.
Otherwise, these kits can be found on Amazon, Ebay etc
Old Jul 10, 2015 | 10:39 PM
Kevinmax's Avatar
removal
so do I just need to insert the tool in the green part and pull it out to get the wires out?
Old Jul 11, 2015 | 06:51 AM
dsonnylal's Avatar
Nope, you remove the wire from the back of the connector
Old Jul 14, 2015 | 02:26 PM
Kevinmax's Avatar
How?
How do I remove it? I've tried just pulling which didn't work nor did a screwdriver in the back side. Do I need to find a small enough spoon to slide around the back side?
Old Jul 14, 2015 | 08:42 PM
Half Assed's Avatar
The wire has a small female pin crimped on it that locks into the connector with a flaired piece of the pin. If you push the wire into the plug from the back and can somehow push it back to the center it will slide out.
IMO, I wouldn't waste my time trying to pull out the pin on that connector. Get a used connector from the junkyard and buttsplice it in or just bypass the connector for that particular broken wire using some T-taps and some spade connectors. Or try sticking a small piece of wire in the hole before putting the other connector on to see you get a good connection then.
Old Jul 15, 2015 | 08:36 PM
Cebby's Avatar
Amazon.com: OTC 4461 6-Piece Terminal Release Tool Set with Case: Automotive Amazon.com: OTC 4461 6-Piece Terminal Release Tool Set with Case: Automotive
LtLeary
Sep 14, 2015 12:33 PM
minsbang
Sep 11, 2015 08:48 PM
