about ground controls
Old Jan 27, 2002 | 12:31 PM
Amendemula's Avatar
do i need a camber kit for them?
if i drop it to the lowest?
i have 16's from the 2001 max
i dont know how low the lowest is ..
but im going to drop it just about the tire..
not tucked...
will it b a rough ride?
ok thanx
Old Jan 27, 2002 | 12:39 PM
krzymax's Avatar
Maxima owner since 2000
Re: about ground controls
not tucked...
ok thanx
hello. you will need a camber kit if you lower the car more than 2''. i believe the lowest you can drop them is 3'' or so. the ground controls are stiff springs and if you have them with the kyb agx shocks then yes, it will be a rough ride.
NightRider's Avatar
not tucked...
ok thanx
Yes to all...
Old Jan 27, 2002 | 12:40 PM
RTF247's Avatar
will will not need camber plates if you drop it at least 2 inches. if you drop it lower than 2 inches you will need them.
Old Jan 27, 2002 | 12:45 PM
Cumalot's Avatar
hm...how come i heard a few members with ground controls saying you don't need a camber kit?
Old Jan 27, 2002 | 02:36 PM
Nealoc187's Avatar
SLOW
You never "need" a camber kit. You just have to decide if you want to buy new tires ever year or not. Maybe those that told you that don't have it dropped all the way.
Old Jan 27, 2002 | 02:49 PM
hooktup98SE's Avatar
not tucked...
ok thanx
i have GC and dropped lower than 2" and yes i have camber plates... i find it to be beneficial for the tire-life...
Old Jan 27, 2002 | 04:09 PM
MaXAnDy's Avatar
how much are camber plates?
Old Jan 27, 2002 | 04:11 PM
NickStam's Avatar
Stillen's are around $300
Old Jan 27, 2002 | 09:34 PM
Supa Lao's Avatar
Would camber bolts be good enough if you lower more than 2"?
Old Jan 27, 2002 | 11:31 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
i dropped my Max 3" in front and my camber was -1 degree so i used camber bolts. Camber bolts allow a max adjustment of about 1 degree. -1 degree camber isnt THAT bad..your tire will wear quicker on the inside but wont be severe. alot of RWD cars have a bit of negative camber and even some factory tolerances allow up to a -.8 degree camber.
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
