Fuse panel door fell off!
Old Sep 16, 2015 | 11:26 PM
Junebug1701's Avatar
Yesterday I was driving around and something fell and brushed against my leg. Luckily, it wasn't a crazed rodent but the little plastic fuse access door above the hood release. It fit back into place but it's very loose and will likely fall off again. Any ideas how to get it to snap in place securely? And no, I don't want to do a "Red Green" fix using duct tape if I can avoid it!
Old Sep 17, 2015 | 04:07 AM
DennisMik's Avatar
Since it is a molded piece of plastic, there isn't anything to adjust. Either a piece of the cover broke off or a piece of the dash opening broke.
You will have to identify what happened and then get creative.
Old Sep 17, 2015 | 08:03 AM
PH98I30's Avatar
A JY might have a replacement for cheap if its broken.
Old Sep 17, 2015 | 12:17 PM
I just inspected the cover and nothing is broken. The opening is OK too, nothing broken there. Wish there was some way to tighten it up.
Old Sep 17, 2015 | 12:32 PM
Fakie J Farkerton's Avatar
Old Sep 17, 2015 | 01:26 PM
Half Assed's Avatar
Old Sep 19, 2015 | 06:29 PM
Daniel VQ30life's Avatar
They fall out all the time on bumps, the car is 20 years old And its plastic, c'mon...
Old Sep 19, 2015 | 07:24 PM
Old Sep 19, 2015 | 08:08 PM
The same door on my 96 Quest never fell off...
Old Sep 19, 2015 | 08:31 PM
Bonka's Avatar
Schnell kaputt
Just bend the tabs so it latches against the trim surround better.
Old Sep 19, 2015 | 10:35 PM
Yeah, that was the first thing I thought of, but with my luck that 19-year old plastic would just crack. I'm thinking about applying some RTV silicone on the bottom edge of the opening and letting it cure.
Old Sep 19, 2015 | 10:38 PM
max ride 41's Avatar
mine fell off 7 years ago, been in the trunk ever since.
Old Sep 20, 2015 | 02:10 AM
bumpypickle's Avatar
if you get a thin rag and put it over the panel and shut it, it should stay shut. There are countless ways to go about fabing something so small like up, this post is really silly haha
Old Sep 20, 2015 | 08:13 AM
maximaham's Avatar
use a heat gun to bend the tabs some to make it fit tight.
Old Sep 24, 2015 | 04:06 PM
I did just that and it seems to fit much better. We just happened to have a heat gun at work. Thank you for the excellent suggestion!
Old Sep 24, 2015 | 09:22 PM
Hitmandan1987's Avatar
There are these little metal clips that go over the plastic tabs that lock it in place. Look on your carpet or around the fuse door area for them.
Old Sep 25, 2015 | 01:54 PM
No metal clips to be found, the plastic tabs are bare. The fuse panel door on our '95 Altima is the same, but it latches on the bottom.
trsandrew
Apr 8, 2016 06:45 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
95naSTA
Sep 21, 2015 06:50 PM
lkiller123
Sep 21, 2015 03:00 AM
