Front suspension questions...
Old Nov 6, 2015 | 09:44 AM
jerrod99_se-l's Avatar
Today got a bad vibration on driver side front...being I don't have abs and have a CAI...I can see most of the suspension pretty easily...I replaced the sway bar bushings in mid summer and end links...ok...now onto the problem...when I push the car back and forth I can see the LCA moving back and forth in the rear bushing of the LCA...so I'm going to assume it needs to be replaced...when I look down at my sway bar bushing I can see it's smashed out of the retainer...my question is will a bad LCA cause pressure on the endlink and sway bar bushing causing them to wear prematurely? Thanks in advance
Old Nov 6, 2015 | 12:26 PM
DennisMik's Avatar
I suppose theoritically yes because every time a bushing moves, it is wearing a tiny bit. But for the most part no. Those are probably the originals and dry rot is setting in.
Old Nov 11, 2015 | 11:21 PM
KP11520's Avatar
When the LCA has travel in ways it's not meant to go, anything even somewhat connected gets tear. AND/OR.... Add a little over tightening possibly on the sway bar retainer nuts (but highly unlikely) and over compress the rubber bushings or (more likely), they weren't seated properly and/or lubed properly, and that adds to the recipe.
I used Moog Problem Solver LCA's and Moog End Links and couldn't be happier! I did however use ES sway bar bushings! Everything is still nice a year later!
I hope this helps!
boomerbrian
Oct 31, 2018 10:25 AM
03VQMAX
Nov 10, 2015 03:39 PM
Colossus
Sep 9, 2015 05:46 AM
boomerbrian
Sep 2, 2015 03:46 PM
maximusrising
Sep 2, 2015 09:55 AM
