Immobilizer bs again...need help with wiring harness
Old Jan 30, 2016 | 03:50 AM
maxima2fst4u's Avatar
Ok guys im tired of this immobilizer bs. I was thinking of just buying a 95 to 97 wiring harness and ecu and go to town. With that said should i or not im cali spec 99 auto and should i just buy a 96 ecu and repin or not. Also im going boost soon as soon that mula hits the bank but need this bs fixed first. Opinions or suggestions? Last time it did this i replaced the immbolizer sensor on the steering and it fixed it till now 3 years later. Also before this all happened i lost all charging from my alternator went and bought a new one and not even 2 days later it kicked the bucket and keep in mind past 2 years the dash has been funky as in quit working it was getting stuck in gears but soon as the gauges started working properly trans would shift out fine so i figured the ecu could have been the culprit the whole time. Lmk what you guys think
Old Jan 30, 2016 | 06:31 AM
'95-'96 would be nice especially if you plan on boosting. Then you can get Nistune.
Old Feb 1, 2016 | 10:42 AM
Yea thats what im shooting for is 95 or 96 you think it youd be best to try and land a 95 or 96 wiring harness as well or just repin my 99 wiring to a 95 or 96 ecu? Either way is gonna be a pain in the *** we all know that but just fishing for ideas mainly lol cant let this keep my girl down
Old Feb 1, 2016 | 05:04 PM
I would just repin.
Old Feb 1, 2016 | 07:45 PM
lux97Max's Avatar
If your looking for a 95-96 manuel ecu, i got a couple in stock.
Old Feb 2, 2016 | 03:50 PM
Im auto but i do know where a wrecked 97 max is 5 speed for 400 bucks...bodys all to hell but engine and trans be worth that and interior is decent
Old Feb 2, 2016 | 04:47 PM
I have a '96 auto ECU if you're interested. Pulled from my SE.
I'm running Nistune and had a spare ECU fitted rather than the one in my car.
Old Feb 2, 2016 | 06:45 PM
lux97Max's Avatar
I have a early production automatic maxima Ecu and harness. Production date of 94 no emissions crap. No purge valve no cannister nothing. Honestly re-pinning can be a real pita if you dont know what your doing. It would probably take you the same amount of time swapping in another harness.
Old Feb 6, 2016 | 01:01 PM
yea idk which way im going..im pretty decent on wiring and i have patience especially when it comes to my maxima lol ill have to think on which would be best cause i need her back up and going here soon
Old Feb 6, 2016 | 01:12 PM
Fakie J Farkerton's Avatar
https://maxima.org/forums/4th-genera...p-success.html
Old Feb 6, 2016 | 10:14 PM
JvG's Avatar
JvG
I installed a by-pass wire in my 1996 a long time ago. No issues. The alarm might not be effective any more, but that's my choice.
I did not modify or even touch my Ecu
Our cars aren't as desirable now as they were when they are new.
In case any one is interested, I can post directions.
Old Feb 7, 2016 | 06:35 AM
Only '99s have NATS so not sure what you bypassed JvG..
Old Mar 5, 2016 | 03:24 PM
I dont think you have a clue what where talking about. Cany bypass something it dont have lol
Anyways after looking at each ecu pins theres quite a few that needs moving. I can do this but will be time consuming im sure but what do i do about bcm that has wires running into it for nats? If i do the re pin does it not mess with duen to nats being gone or what. I'll have to think thisnover might just try to find a 95 ecu and engine harness and go from there lol also what about certin pins that the 95 dont use anything but my 99 does can inuse those blanks or not.
Old Mar 5, 2016 | 08:34 PM
Originally Posted by Fakie J Farkerton
Old Mar 5, 2016 | 11:14 PM
deloa84's Avatar
Don't waste your time replacing an entire harness which may take you a couple of hours to a day or more. Get a 95 96 ecu. Moving pins took me and a friend a matter of about an hour and the car was up and running with no NATS. As far as I know there is only one wire for the NATS and that one is simply cut and removed and I reused it for the fuel pump. Read carefully the instructions, print out the ecu pinouts available from here => http://www.nicoclub.com/nissan-service-manuals
and it should work.
Old Mar 5, 2016 | 11:20 PM
deloa84's Avatar
Go back and read the link Fakie posted. There's only 5-6 pins that you need to switch around to get your car up and running with a 95 96 ecu...
That's not a lot... Trust me it's way easier to swap 6 pins than it is an entire engine harness.
EDIT:
to answer your question, yes the 99ecu does have more 'stuff' than the 95ecu. Meaning the stuff that isn't needed by the 95 won't be used/recognized. But you still retain OBDII compliance with 95. And you don't need to do anything with the bcm a few have already done the swap on automatics with success.
Old Mar 8, 2016 | 01:56 PM
sorry guys i failed to post that i found the old post from years back i could use for my re pinning lol anyone wanna donate a ecu for time being for me lol jk i have to find one. Ill probably just buy from another org member but im also gonna have fun with tcm as well for this swap...im sure ill figure it out, then from there im going to start building a turbo set up for her and get everything i need after a good test run with the re pinned ecu
