how do you tigten the drivebelts?
Re: how do you tigten the drivebelts?
Originally posted by buss95max
i know you need to loosen the center pulley on one and use the top **** to move it. My question is how do you tighten the belt near the firewall.
If you're talking about the power steering belt, there is a bolt on the back side of the bracket that the whole assembly slides up and down on. I had to put my car up on jack stands and go at with some extensions and a universal joint to reach it from below and behind. It's kind of a PITA to do. If you can borrow a service manual from a friend or even the library, it will show you pictures and guide you through it, as it's almost impossible to describe without actually having you see it.
SuDZ
If you look closly at the Haynes pic, it shows the Y pipe removed. Although I didn't have my car on lifts, it still didn't seem as though a lift would get me in there. I had to call it quits on trying to change my power steering belt until I got it on lifts or come here for some tips.
~scott
'96SE
Guys, help me on this steering belt. I don't have problems
with the alternator belt. The power steering belt
is the one that I can't replace. To be specific,
I did loosen the nuts that are visible from the
left front tire side. However the power steering
is still snug and won't come down.
Is there another nut holding this unit in place?
thanks...
thanks...
Re: Guys, help me on this steering belt. I don't have problems
thanks...
thanks...
SuDZ
beach50
Dec 26, 2014 06:51 PM
Ladzio
Oct 4, 2004 04:06 PM
