Oil Leak Pictures
175k miles I think alternator went bad and when I removed it the thing had oil all over it. I have never replaced any gaskets and would like input on where you guys think I'm leaking from, it looks like the sources are near the crank pulley and directly above the alternator
https://cimg5.ibsrv.net/gimg/maxima....1793fdcab2.jpg https://cimg4.ibsrv.net/gimg/maxima....d7d7b19d25.jpg https://cimg5.ibsrv.net/gimg/maxima....e4eed141cd.jpg https://cimg7.ibsrv.net/gimg/maxima....e4e52cc91c.jpg |
You should replace both valve cover gaskets and camshaft position sensor gasket.
Originally Posted by uttadms31
(Post 9140308)
Get the camshaft position sensor gasket OEM from a dealer or online OEM so you get the exact size (will be ~$6). For the valve cover gaskets, Felpro works well...This is what I used a couple years ago:
http://shop.advanceautoparts.com/p/f...e+cover+gasket Edit: You may have other leaks as well, but these two are obvious. |
I'm calling cam/valve cover gasket(s) and likely the upper oil pan gasket.
There may be others but due to the mess one can't really tell. This is one of those classic situations wherein a clean engine bay can be exceedingly helpful. My advice would be to start with the cam/valve cover gaskets. Once those are replaced, clean the sh*t out of that motor then keep an eye on things. |
1st pic looks like potential for front crank seal needing to be replaced. I had a similar condition where the crank sensor kept getting covered with oil and road grim, and therefore impacting starting. Unfortunately, to replace the front crank seal, the flywheel pulley needs to come off.
If you remove the flywheel pulley, check the rubber between the two pulleys for deterioration, and replace if needed. |
Does it smell like fuel? Sometime injectors can leak and dump fuel into the cylinder and it winds up mixing into the oil somehow thinning it and eating at the sealant.
1 Attachment(s)
Originally Posted by maximatech12
(Post 9140524)
I just pulled that rusted coolant pipe from my 5th gen and it was seized into the fitting. Mine both have to be replAced completely!
Here's a thread about it below. https://maxima.org/forums/4th-genera...ter-pipes.html https://maxima.org/forums/4th-genera...ml#post9130500 Three years later.. Attachment 12086 |
Thanks for the links! I cut the ends off of them and now running 3/4" hose from the ends across the front over the exhaust to the heater core/water control regulator.
I gotta buy a T for the return from the throttle coolant. They apparently have 3/4" stainless steel flex pipe too |
© 2024 MH Sub I, LLC dba Internet Brands
