Rear Strut Bolt Came Out Stripped and Then Got Stuck
Old Feb 24, 2017 | 11:33 AM
Violator's Avatar
My lower rear strut bolt when going to put coilovers on came out 80% of the way, completely stripped! There's almost no threads on it. Now it's stuck and just spins in place, how am i gonna get this out and do any stores carry these?
Old Feb 24, 2017 | 08:34 PM
DennisMik's Avatar
Are you talking about the bolt that holds the bottom of the strut attached to the trailing arm? Just cut the nut off and buy a new bolt.
Part # 55080-2L71A at the dealer, $2.58. (this is for a 98 or 99. 95 - 97 has a different #)
https://www.nissanpartsdeal.com/part...agram=431_A002
Old Feb 24, 2017 | 09:44 PM
Violator's Avatar
I did this earlier today, hopefully gets here monday or tuesday. Good thing I tried the other side, same exact result the threads were non existent as soon as i could see them so i just stopped there and ordered 2 new bolts, still have to get the original stripped ones out like i said the first one just started spinning in place
also, seems like nissan redesigned the bolts they sell now, which i'm glad to hear. This car is from southern cali, i live in ohio and my first maxima was rusted underneath to the point it scared me i'm surprised my struts didn't just slip off with the quality of these bolts
Old Feb 25, 2017 | 06:46 AM
CS_AR's Avatar
I just bought a set of nuts and bolts for the 98 and 99 model to use when I replace torsion link bushings.
Would you post a picture of the old bolt?
The new bolts look different from what I remember about the old bolts. I could be wrong though.
Old Feb 25, 2017 | 10:59 AM
Violator's Avatar
looks about the same to me
I just removed that, and the whole car dropped a bit and scared the **** out of me i wasn't thinking of the rear suspension bar being supported by the struts, where is the best spot to jack for rear strut removal?
Old Feb 25, 2017 | 11:25 AM
jholley's Avatar
I place jackstands under the LCAs in front and between the rocker panels and trailing arms in the rear. For cushioning I place squared 4x4s on top of the stands. Same spots as Ben's Jack Points in this diagram
Some members replace the rear shocks 1 at a time for safety precations. With the rear beam bolted onto the chassis with the trailing arms and lateral link I remove both at once.
Violator
Feb 26, 2017 05:15 AM
soflamax
20
Aug 7, 2015 04:17 AM
theWalkinator
Apr 11, 2014 01:31 AM
Defiant_Max04
23
Jun 10, 2007 09:10 PM
Chinkzilla
Mar 19, 2003 10:47 PM
