Forgot to unhook battery now car wont start
Old Mar 27, 2017 | 06:10 PM
isaac2nyce's Avatar
My car (99 Maxima gle) was having issues with the air/heat (only blew hot air). so i did my research and found out it was an "Actuator switch"....long story short i tried replacing it myself and forgot to unhook the battery first. now my car wont start. it cranks, but wont start. i replaced the battery, everything electrical works fine inside. i also replaced the radiator fan 1 fuse (FL 30A) after seeing it was blown but still no luck. Any Ideas???
Old Mar 28, 2017 | 07:34 AM
CS_AR's Avatar
Are you seeing this security light? If yes, NATS may have accidentally immobilized your vehicle.
Do you have a spare chip key that you can try?
Old Mar 28, 2017 | 09:14 AM
isaac2nyce's Avatar
yeah, security light works and all, but no spare chip key..i also notice when i try to start the car my revs arent moving. couldnt that be the fuel pump? whether it be relays or fuses possibly blown? fuel pump was working fine before i took the battery off. i cant even hear it now when i cycle the key.
Old Mar 28, 2017 | 10:14 AM
CS_AR's Avatar
If the security light is solid red, the car may be immobilized and the fuel pump will not work. Search for NATS and immobilizer to see the issues from immobilization.
Old Mar 28, 2017 | 12:19 PM
Shrout1's Avatar
I had to get my car towed to the dealer and get my ECU / keys reprogrammed when it immobilized on me. Cost about $75.
