Cruise control malfunction?
Old Jul 23, 2017 | 10:08 PM
97MaxiCoy's Avatar
This randomally started to happen, I can turn the cruise control switch on on my 97 maxima gle, and the green light shows up (on the button) but when I go to set the cruise say at 60mph it doesn't register and It's not working... any thought on that ? Thank you.
Old Jul 24, 2017 | 01:35 PM
allmazda's Avatar
Two issues. The set button is not making a connection when depressed or there is junk stuck between the buttons and it is pressing the cancel button as well.
Or your cruise and/or brake light switch is not working correctly. The ones on the brake pedal.
Old Jul 24, 2017 | 01:58 PM
Icemule's Avatar
This happens to almost everyone. Get down under the steering wheel and look up on the brake pedal. You will see two plactic buttons in the brake pedal. One button is for the brakes and the other plastic insert button is for cruise control, thats probable missing, in fact look on your floor board and you will probable see it broken lying on the floor.
Two ways to fix this, one is to super glue a dime over the hole or get another plastic button from a junk yard. I went to the junk yard and got another button off of another car that was stronger than the cheap plastic one Nissan used, don't remember what kind of car I took it out of, but I tested it in another Maxima at the JY, and it fit, was a little tight, but it has been working for 2 yrs so far. One more thing, unless your bone skinny, it's kinda hard to see it, look up it's location on google. I found a video for you using the dime method even though he used a qtr, so if your rich, use the qtr.
You can do this without taking out the seat if your skinny, but I weigh 200 lbs and was able to do it without taking out the seat, if you take out the seat it's 4 14mm bolts, pretty easy really. good luck and report back if that was the problem, if not then we can go from there to help you. Good luck.
Old Jul 25, 2017 | 02:03 PM
allmazda's Avatar
If I am not mistaken, the cruise light on the cluster will flash when the cruise is turn on via the dash switch when either the brake light or cruise control switch on the petal are not functioning correctly.
Old Jul 31, 2017 | 02:42 PM
97MaxiCoy's Avatar
https://www.youtube.com/watch?v=H1HDU72q2Rw
This is what I found under the pedal. So what I'm guessing you're talking about is the blue connector with a switch, that when I press the brake in it clicks it? Idk but thAts what I found
