Positive cable power fuse
Old Aug 21, 2017 | 03:43 PM
nissan99's Avatar
Just had a question on the positive cable battery fuse .. I just seen two tabs on top and tried to push them in to check the fuse .. could not do it , is there a way to open it and check it or does it pop off to replace it ?
Old Aug 22, 2017 | 05:41 AM
Violator's Avatar
Is that the 140/120amp white fuse? If so theres a bolt on the side of the fuse you have to remove
Old Aug 22, 2017 | 02:10 PM
nissan99's Avatar
its the red plastic end for the main fuse in line .., I think it's 140 amp it on the end of positive cable
Old Aug 22, 2017 | 02:38 PM
nissan99's Avatar
It right at the end you can see two tabs were I tried to push in
Old Aug 27, 2017 | 11:03 PM
nissan99's Avatar
Or is it a separate power wire ? Cause some how it was not making contact with positive clamp and I had no power at all nothing...
Old Aug 28, 2017 | 08:44 AM
DennisMik's Avatar
It is a separate wire, the car's electrical system is split in two. For example the headlights don't go through that fuse but the alternator and power windows & seats do.
Old Aug 28, 2017 | 10:36 PM
nissan99's Avatar
Ok Dennis so what do they call this part ? Can you still get this ?
Old Aug 29, 2017 | 11:51 AM
DennisMik's Avatar
I cannot answer your questions. I could not locate it in the parts listings. That doesn't mean it is not available. If you try looking up things in the parts listings, you would understand my statement.
Call a dealer and talk to the parts department, they are usually pretty willing to help. Or you could go junk yard hunting.
