inside drivers door handle problem....
i went to open door while door was locked and i heard a snap! now the handle is loose and won't open the door if lock is engaged. it will work if i simply unlock door first but handle is still loose. looking at the plastic trim piece there is some plastic missing where the lock meets the trim piece, but i think i need a replacement door lock mechanism? lock still works with key fob and door control, what did i break? thanks
Is this the inside Handle?
Whichever it is, I think it might be one of the plastic "things" (pardon my technical terminology) that hold the ends of the various rods into the bellcranks. There are probably a half dozen of them.
See page 10 for the rods inside the door - http://boredmder.com/FSMs/Nissan/Maxima/1996/BT.pdf
I had to replace the outside door handle on my 97 and that was a miserable job. I think that was when I learned to take the window glass out anytime I had to work inside the door.
Hopefully, it's not the color-coded handle. One of the plastic tabs that is used to hold the lock barrel in place broke making it impossible to lock the door on the 99. I found a replacement in a junkyard but the bolt that holds the handle to the body stripped when I tried to remove it. So finally I gave up and ordered a Dorman replacement. It is black plastic. It doesn't really match the super black paint. I hope you have better luck than me.
Here's a picture of the new Dorman door handle. I think I got it from Rock Auto.
The part that broke on the original handle was one of the tabs that holds the lock barrel in position.
When I tried to remove an original type handle from a junkyard car, to replace my broken handle, the parts that hold the bolts with the red "V" marks, would strip out. I tried using different types of glue, but that didn't work. So I gave up and bought the handle in the picture.
You might be lucky and only have a broken part that holds the rod to the bell crank like Dennis described.
TheIntrepidMontti
09-29-2011 07:19 AM
burtonmaina
03-25-2010 05:24 PM
