Front motor mount sensor?
Old Jan 16, 2019 | 02:40 PM
discobiscuit's Avatar
I have a 95 Maxima and just replace the front motor mount. This mount has a sensor in it and was hoping someone could tell me what this sensor is supposed to do. I’m NOT a mechanic but I’ve never seen or heard of a sensor in a motor mount before. Thanks.
Old Jan 16, 2019 | 03:34 PM
PH98I30's Avatar
The front mount is liquid filled. When the car is idling the mount expands (or contracts, I don't remember which) to smooth out the feel of the car. When you accelerate the mount deflates. I cannot tell one way or the other. You supposedly get a stiffer ride with the solid mount. A lot of orgers here just replace the mount with solid mounts when the time comes due. Manual trannies have the solid mounts.... I think.
Old Jan 16, 2019 | 04:22 PM
Slamrod's Avatar
basically this in a nutshell. however you *NEED* to keep that sensor unplugged, unless you want to risk the fluid eventually leaking out, causing a short with the sensor, and having it fry your ECU and leave your car dead.
Old Jan 17, 2019 | 06:07 AM
CS_AR's Avatar
It is electrically controlled to expand and contract a jell like fluid to smooth out engine vibrations (in automatics) while driving. As the cars get older, the rubber cracks, the fluid leaks out, and sometimes the electric part develops a short. The 5th gens have a problem with a shorted mount blowing out the ECU. I either use a front mount from a manual transmission without the electric dampner, or run with it unplugged. It doesn't throw codes if the mount is unplugged. I prefer a more direct feel anyway.
Old Jan 17, 2019 | 02:03 PM
PH98I30's Avatar
^^^^^ I forgot about the ECU frying. I was told on the '98 they don't fry. Better off unplugged.
athlon omega
47
Mar 21, 2015 02:07 PM
jtricer1973
Mar 2, 2014 10:15 PM
kurt1
May 23, 2012 11:52 AM
randy021186
Aug 16, 2007 05:36 PM
Dreizehn
Feb 17, 2004 12:06 PM
