Tired of this intermittent idle issue.
Shot a video of this idle issue I've been dealing with for months now. Not sure where to start. Well, already did with 6 new Hitachi ignition coils. With $300 already down the drain I figured I'd throw a video up and see what the forum thinks.
Thank you all in advance! |
Regarding the hard starting after shut down, does it only do that when the car is warmed up? If so, could it possibly be related to a leaking fuel pressure regulator or maybe a bad coolant temp sensor?
Originally Posted by skywalker85
(Post 9196123)
Thank you all in advance! https://youtu.be/fpwvfX-xPPE |
Look into the condition of the fuel injector(s) and the adjustment of the TPS.
Also, instead of flicking the accelerator to to 7K RPM to break it out of it's stupor, how do things act if you very slowly and smoothly increase the engine speed? And for the record ... having spent $300 on brand new OEM coils is not money down the drain. That was a wise move in my opinion. |
Originally Posted by Zerodrag
(Post 9196125)
(Post 9196147)
Also, instead of flicking the accelerator to to 7K RPM to break it out of it's stupor, how do things act if you very slowly and smoothly increase the engine speed? And for the record ... having spent $300 on brand new OEM coils is not money down the drain. That was a wise move in my opinion. Yes $300 is not bad compared to the OEM coils. But it's still $300 I spent on a part that was working. |
So you guys are thinking:
Fuel pressure regulator Coolant temp sensor Injectors (where should I pick these up from)? TPS (How do you test or calibrate this one)? Would this have anything to do with the EGR system? I had cleaned out the EGR guide tube and tested the sensor summer of 2018. |
(Post 9196165)
(Post 9196165)
Fuel pressure regulator Coolant temp sensor Injectors (where should I pick these up from)? TPS (How do you test or calibrate this one)? Would this have anything to do with the EGR system? I had cleaned out the EGR guide tube and tested the sensor summer of 2018. Another item that I didn't read has been looked at this the MAF. Does the idle/deceleration symptom seem to be at all related to engine temp ... i.e does it only show itself when the car if cold or when it's at operating temp. or does it even matter? Here's a link to the FSM for the '99 model year. TPS stuff is in section EC: http://www.boredmder.com/FSMs/Nissan/Maxima/1999/ If yours isn't a '99, here's a link to parent directory: http://www.boredmder.com/FSMs/Nissan/Maxima/ |
The vehicle fires right up when it's cold. The idle issue shows itself right away. And sometimes it does not. But when the idle is an issue at operating temps and I shut the vehicle off it's a pain in the *** to fire back up unless I give it gas or let it sit and cool down.
I'd like to start with the small easily accessible parts and leave the big jobs for the end. Like the injectors. Especially the rears. But not sure what to start with. This vehicle has been good to me for yrs. I'd like to fix it and keep going. Out of all the cars I've owned this ones my fav. Gone from a brand new 07 Maxima to an 01 and now the 95. |
If you want to start small look at the connections on your MAF and clean it. Also clean/spray your throttle position sensors with electric parts cleaner.
Could also try cleaning the cam position sensor since it's easy to get to and has been known to get oiled up to cause intermittent starting issues. Should be up top on the timing chain cover area, i think. If anything, it's a good preventative issue even if it doesn't solve your issue.
The idle air control valve is responsible for idle management. They need cleaning eventually.
I think that's what your problem is. |
What is your year model?
You're exhaust almost has the same rhythm my car had when I was experiencing fuel problems. Check your injectors...I'm thinking its fuel related, check throttle body, the boot and etc. I've noticed a lot of 4th gens recently are starting to experience fuel problems due to age.
Do something to clean out the fuel lines because when you revved and the problem went away, that's a sign it's either fuel/air related..something is not flowing smoothly. |
(Post 9196165)
Fuel pressure regulator Coolant temp sensor Injectors (where should I pick these up from)? TPS (How do you test or calibrate this one)? Would this have anything to do with the EGR system? I had cleaned out the EGR guide tube and tested the sensor summer of 2018. otherwise, Ohm test the injectors. if you do end up buying some, get new and not reman. EGR can cause idling issues if its plugged or the valve is acting up, but as said check IACV before anything else. |
Originally Posted by JvG
(Post 9196184)
How to test your IACV.
If you have a good IACV, then I would read you plugs after a misfire episode to identify a plug that may be getting too much fuel. I had a myriad of hard to start issues from flooding caused by leaking injector o-rings with cracked pintle caps. I bought an injector kit from eBay for $34 that contained new screens, o-rings, and pintle caps and refurbished my own. That was well over 5 years ago. We see so many issues caused by leaking rubber injector o-rings that is becoming one of those standard maintenance items like radiator and vacuum hoses. They just deteriorate over time. Pictures: https://i286.photobucket.com/albums/...psdba69046.jpg Injectors with leaking o-rings and broken pintle caps. http://i286.photobucket.com/albums/l...pscp7iddyr.jpg Injectors that would have soon caused problems. http://i286.photobucket.com/albums/l...psi0kojavo.jpg Injectors that I refurbished. https://i286.photobucket.com/albums/...psmd85h4qe.jpg Other pictures http://i286.photobucket.com/albums/l...psmgpsfhtm.jpg Cap insulators. http://i286.photobucket.com/albums/l...psragiprnd.jpg Link to a thread on replacing injectors. https://maxima.org/forums/test-posts...ment-tips.html Link to a thread on how to refurbish your own injectors. NOTE - Depending on your comfort level with tackling engine projects at home and time the car can be take out of service, this may not be for you. Its easier to send your injectors our for refresh service and test, than to refurbish your own. I just want to do myself to see if could be done. https://maxima.org/forums/test-posts...struction.html IF YOU DECIDE TO REPLACE YOUR INJECTORS, BE SURE TO OIL THE O-RINGS BEFORE INSTALLATION. We read about people who do not oil their new injectors and pinch the o-rings on installation. |
Originally Posted by CS_AR
(Post 9196220)
(Post 9196256)
https://www.youtube.com/watch?v=BYuRKzsqp-g If you have a good IACV, then I would read you plugs after a misfire episode to identify a plug that may be getting too much fuel. I had a myriad of hard to start issues from flooding caused by leaking injector o-rings with cracked pintle caps. I bought an injector kit from eBay for $34 that contained new screens, o-rings, and pintle caps and refurbished my own. That was well over 5 years ago. We see so many issues caused by leaking rubber injector o-rings that is becoming one of those standard maintenance items like radiator and vacuum hoses. They just deteriorate over time. Pictures: https://i286.photobucket.com/albums/...psdba69046.jpg Injectors with leaking o-rings and broken pintle caps. https://i286.photobucket.com/albums/...pscp7iddyr.jpg Injectors that would have soon caused problems. https://i286.photobucket.com/albums/...psi0kojavo.jpg Injectors that I refurbished. https://i286.photobucket.com/albums/...psmd85h4qe.jpg Other pictures https://i286.photobucket.com/albums/...psmgpsfhtm.jpg Cap insulators. https://i286.photobucket.com/albums/...psragiprnd.jpg Link to a thread on replacing injectors. https://maxima.org/forums/test-posts...ment-tips.html Link to a thread on how to refurbish your own injectors. NOTE - Depending on your comfort level with tackling engine projects at home and time the car can be take out of service, this may not be for you. Its easier to send your injectors our for refresh service and test, than to refurbish your own. I just want to do myself to see if could be done. https://maxima.org/forums/test-posts...struction.html IF YOU DECIDE TO REPLACE YOUR INJECTORS, BE SURE TO OIL THE O-RINGS BEFORE INSTALLATION. We read about people who do not oil their new injectors and pinch the o-rings on installation. |
My IACV has some carbon buildup but the shaft does move back n forth like in the video. Does this mean the problem is elsewhere?
Also every single vacuum hose has been replaced summer of 2018. I don't think there is a vacuum leak. If there was the idle would always act up. Not come n go right? I'd like to check everything else and save the injectors for last. Only bc I'd have to pull the plenum off again and the vehicle would be down for awhile. |
Plugged in the Nissan-14 Conzult and ran some live data during poor idle and good idle conditions. Here's what I got. Hope someone knows how to read this bc I don't understand any of it.
https://cimg8.ibsrv.net/gimg/maxima....1b2314fd8a.jpg Nissan-14 Conzult ECU Talk Data |
Have we checked for vacuum leaks? Tried seafoam in the intake and gas, or some other injector cleaner in the fuel?
basic easy stuff, then I'd say pull another iacv from a junkyard (hopefully oem) |
Originally Posted by Violator
(Post 9196393)
Vacuum leak test complete. Haven't tried any seafoam or injector cleaner yet. Whats the proper/best way to get those done?
(Post 9196402)
part of the bottle goes in the gas. part goes down a vaccuum hose such as the brake booster. You would have a better chance of success if you disassemble your iacv, then thoroughly clean it with carb spray. While we are on the subject of sprays and cleaning things. Buy some CRC Throttle body spray. Clean the inside of your tb and especially the edges of the throttle. Might as well also buy a bottle of CRC maf spray. Clean your maf with it. You will use these sprays again someday . |
Won't I experience more idle issues after cleaning these parts? How will the vehicle relearn proper airflow?
I'll give these all a shot but also worried I may make things worse. |
(Post 9196406)
(Post 9196406)
I'll give these all a shot but also worried I may make things worse. The ecu will adjust to the new conditions soon enough. I have personally done all these things on my own car. |
(Post 9196426)
... then do your maf carefully not to spray the sensor in the middle, just wipe out the tube around it ...
The point of cleaning the MAF is to clean the sensor wire. Care should be taken not to "touch" the wire but cleaning the wire with an appropriate spray applied solvent/cleaner is what cleaning the MAF is all about. |
From watching the video a couple of times and hearing the situation, it appears to me the issue is from engine running way too rich. The engine appears to be cold when this too rich condition is occurring. I believe:
1) When the engine is misfiring and you stop the engine, you are required to hold the accelerator in WOT position to get it to restart. This is clearing a flooding condition. Way too much fuel is being dumped into the cylinders and causes it to flood out. 2) When you rev the engine up to 7,000 RPM, it clears up. At high RPM the engine is burning off the excess fuel. Does the problem return if you let the engine idle for a while after revving it to 7,000 RPM? I would remove and read your spark plugs during a misfiring episode to check for a wet plug or plug that appears to be receiving way too much fuel. Possible contributors to a rich condition on cold engine are: 1) Leaking Fuel Pressure Regulator. 2) Leaking Injectors |
(Post 9196468)
Sorry but this is just wrong.
Originally Posted by User1
(Post 9196652)
Perhaps it might be, for you, for a little while. That attitude does get in the way of receiving the kind of advice you might need some day, when you need it most. Old Man Murphy and his friend Instant Kharma might pay you a visit at an inconvenient time. They usually do, as a team. |
© 2024 MH Sub I, LLC dba Internet Brands
