99 maxima gas leak
Old Mar 12, 2019 | 03:44 PM
Adventuredude's Avatar
99 maxima gas leak
I posted awhile back and cant seem to fund my old post . So anyway 99 maxima with lots of gas leaking out , just pulled the fuel rail since we started it and didnt see any gas comming from anywhere but the from . One of the injector seals was ripped /messed up that the injector pushes into . The problem is now that the fuel rail is off we cant figure out what's leaking . This was a huge leak puddle under the car , had tons of smoke as well comming from the tail pipe . What should we do order pressure regulator ? I already ordered 6 bushings or whatever they are called that the injector pushes into .
Old Mar 14, 2019 | 10:03 AM
Next step
The rubber injector rings came in. What else should I do/check before I connect the fuel rail back up to stop the leak ?
Old Mar 14, 2019 | 10:06 AM
Leaking lots of fuel
By the way it on leaks with the key on and running does not leak when just sitting there ?
Old Mar 14, 2019 | 11:35 AM
JvG's Avatar
JvG
You should also replace the fuel line hoses.
They could leak eventually. Be sure that you buy fyel hose intended for fuel injection.
The fuel pump pressurizes the system. It will stay pressurized for some time after the key is turned off. Unless something is leaking of course.
Old Mar 14, 2019 | 01:37 PM
Jack Sh!t's Avatar
Proper installation is the key to those o-rings not ripping. Use a little fresh oil and rub it along the o-rings and the fuel rail housing for the injector. Makes it easy to slide into place and not tear up those rings, which causes the leak.
Old Mar 14, 2019 | 01:50 PM
JvG's Avatar
JvG
Originally Posted by jack ****
proper installation is the key to those o-rings not ripping. Use a little fresh oil and rub it along the o-rings and the fuel rail housing for the injector. Makes it easy to slide into place and not tear up those rings, which causes the leak.
+1.
Old Mar 14, 2019 | 01:56 PM
PH98I30's Avatar
If you run TCW-3 in your gas, it will keep those injector O-rings lubed and your injectors clean.
MaximaFan4140
Feb 27, 2010 12:37 AM
Weimar Ben
Feb 26, 2010 10:20 AM
1993-VG30E-GXE
May 11, 2008 03:18 PM
mooze
Jul 15, 2007 05:11 PM
s1rch
Sep 14, 2001 05:33 PM
