Does 99 maxima need reptogramed after replacing bcm
I think my bcm is bad. If i buy a used bcm from a 99 maxima can i just plug it in and car be fine or it have to be reprogrammed. Thanks for any help
Is there a way to reset my bcm. Does removing negitave battery cable for 15 minutes reset bcm
I replaced mine and didnt have to reprogram anything. I just unplugged the battery and took it out and plugged the new one in and plugged it back up and its been fine.
I have a spare that works if you need it. Just have to make sure the numbers on yours match and all. What year is your car? |
My car is a 99 what year is yours
My 99 maxima 3.0 auto
Bcm Part # 2ht 28491 4l 700 8z18 I found a lot of used bcm on ebay but couldnt find one that all 3 sets of numbers matched up. Closest 1 i found was from a 99 maxima with manual trans the bcm # 2ht 28491 41700.i thaught manual trans would be different than auto. I have no idea what trim level my maxima has |
Originally Posted by Jphipps440
(Post 9197540)
Does mine have to come from an auto. Or will it work as long as it has the numbers are 2ht 28491.4l 700. Can a bcm also cause a random misfire
(Post 9197551)
It has been said that the 99 coil packs are sh!!tty. That is probably the misfire problem. Any ehgine codes to report?
It has a 0300 engine code. I put new spark plugs in it and new coils. Sometimes it has a 1105 code. I cleaned map senspr and i can feel the map switch sylonoid clicking when key switch is turned on
Those are intake manifold codes. Check for manifold leaks. Only use NGK spark plugs.
Thanks for the info. Ngk is the plugs i used. Tomarrow i will check for manifold leaks. When warm idling in gear sometimes it will idle rough while driving it runs smooth. I even changed fuel filter thinking that would help. I ordered a bcm off ebay hoping it will fix my windows locks cruise control and rear defogger
(Post 9197607)
Thanks ill check the rear window switches. I baught the car with windows and stuff not working. I fixed the rough idle issue. You was right it was a vacumm leak. I found a small vacum line unplugged from the manifold runs and idles good now. Next is to fix the windows. I love this forum lots of smart people with good info.
When you need parts like switches and handles and that crap, go to a junkyard where the parts are cheap. Also, If you need to see how something is hooked up, sometimes you can see how it is done looking at a junkyard car. Usually things are in normal shape after a wreck except for the smashed parts. A junkyard is a good go to place.
I replaced bcm today. Same thing i have no rear defogger no speed cruise windows and locks dont work. Dome lights dont work with doors key ring dont light up. I checked rear window switches to make sure they werent on wrong sides. I have no idea what to try.
You have checked the fuses already i assume?
Yes i checked all fuses with a testor there all good. I tried switching relays beside under dash fuse box.
I got key ring lite dome lights and elec. Door locks working still no elec. Windows. For some reason door locks automatically unlock them selves as soon as there locked. I cant figure out whitch relay goes to windows
I double checked fuses. Under dash fuse box
two fuses not getting power #5 marked tail lamp 7.5a #18 marked interuor illumination 7.5a What can cause both fuses to not have any power. My tail lights and dome lights are working. Thanks for any help you can give |
(Post 9197910)
two fuses not getting power #5 marked tail lamp 7.5a #18 marked interuor illumination 7.5a What can cause both fuses to not have any power. My tail lights and dome lights are working. Thanks for any help you can give Maybe you have a faulty window switch? Snag one from a junk yard and test. Only time it would unlock soon as you lock it was if the key was in the ignition typically. This is interesting. I wish i could be of more help. |
Oh your right i just tock the key out and it stayed locked my mistake. I baught two master window switches and none work the windows. I can lower and raise window by hooking wires straight to window motor harness. When i push window button i can hear clicking
Solved. It was a bad switch wire to rhe power window relay. The red wire with grey stripe for switched hot into the power window relay wasnt getting juice. I hooked that wire to a fise link and to battery and windows cruise control and rear defogger is working good. I need to find a better place to hook the wire but everything works now. The relay is behind driverside kick panel. It has white/red wire yellow/red wire black wire red/ gray wire. Thanks for all the help
© 2024 MH Sub I, LLC dba Internet Brands
