5 speed swap help
Old Jan 12, 2020 | 09:27 AM
2DAMAX98's Avatar
5 speed swap help
Hello, Im about to swap in my 5 speed LSD and wanted to look over the procedure but the links I have for it no longer work, including in the stickies. Does anyone happen to have a good link for it or have it saved to a file they would be willing to share by chance. Thanks in advance!
Old Jan 14, 2020 | 05:28 PM
lux97Max's Avatar
Its the same procedure, all you have to do is change over the driver side axel since vlsd is different.
Old Jan 14, 2020 | 07:57 PM
2DAMAX98's Avatar
Same procedure as what? I think you misunderstood the question. Im looking for the procedure!
Old Jan 15, 2020 | 01:03 AM
lux97Max's Avatar
Lol so your automatic coverting to 5 speed?
Old Jan 15, 2020 | 04:24 AM
2DAMAX98's Avatar
Yes, there is a link to the procedure of how its done but the link no longer works.
Old Jan 15, 2020 | 05:48 AM
krismax's Avatar
Father of the 00 VI
Unfortunately ,no one is looking after the treasures on here.
Many things people ask about have already been done or talked about.
But it is being lost to time,it's a trove of knowledge.
For instance
how many people could perform these things . There are many more on this site,or they were.
1. Secret sauce
2. 00 VI
3. PF TB swap
4 EGR delete
Old Jan 15, 2020 | 06:32 AM
2DAMAX98's Avatar
I agree. I was just hoping maybe someone had saved it. I saved the link and always ment to print it out but by the time I got around to it the link no longer worked😡 Im fairly knowledgeable about this cars but just never done this to one. Guess I will just have to wing it.
Old Jan 15, 2020 | 07:04 AM
lux97Max's Avatar
I dont have a write up but i do know how to do it. I do have all the parts neccessary for the swap aswell. Post what your stuck on, on here and ill reply best as i can. To put it easy for you the hardest part is taking the dash apart to install the clutch pedal and wiring in the sensors on the pedal., if your swapping in 5 speed harness which is a good idea, that part isnt to fun either. Once you get passed those to parts its not to bad.
Old Jan 15, 2020 | 07:35 AM
Did you try this?
https://archive.org/web/
Old Jan 15, 2020 | 07:53 AM
2DAMAX98's Avatar
The bash part wont be a problem since I will be swapping the interior out for another car at the same time. I believe I have everything I need for the swap except for the wiring. I honestly didnt even know there was any wiring to be done. Im pretty good at that kind of thing so if you could just let me know what I need to do there that would be a huge help.
Old Jan 15, 2020 | 07:58 AM
2DAMAX98's Avatar
Did you try this?
That didnt work either, was hoping it would but no go. Thanks though.
Old Jan 15, 2020 | 08:42 AM
lux97Max's Avatar
Yeah man i got a few engine harness along with ecus. So if you need a part that wont be a problem.
Old Jan 16, 2020 | 09:58 PM
DizzyEdge's Avatar
What does that mean?
Could you paste the (broken) links you have?
Old Jan 17, 2020 | 05:27 AM
2DAMAX98's Avatar
https://redirect.viglink.com/?format...orums&txt=Link
chico123
66
May 22, 2011 08:06 PM
cmoe211
Sep 1, 2008 11:01 AM
95turbo gxe
Sep 29, 2006 12:42 PM
