Stalling
Old Aug 12, 2020 | 12:10 PM
Guralt's Avatar
Stalling
HELP!!! 1997 Maxima 6 cylinder. Stalls at low RPMs, difficulty starting and chugging at higher speeds. Tried replacing
fuel pump, camshaft position sensor, mass airflow sensor, fuel filter, throttle position sensor, crankshaft position sensor, cleaned throttle body and STILL STALING. No code either, help
Old Aug 12, 2020 | 02:38 PM
Check for vacuum leaks.
Pull your plugs and check the health of them. Post pics here. They may tell you the story of what's going on...ie bad injector(s).
Old Aug 12, 2020 | 03:13 PM
KP11520's Avatar
Throttle Body is done, so that leaves the IACV.
That's where I'd go next!
Old Aug 12, 2020 | 06:21 PM
aembleton's Avatar
I had this issue on my 98 it was vacuum leaks and failing ignition coils
willy431
Mar 27, 2004 05:55 AM
flipmode_cali
Mar 11, 2004 05:44 PM
nismomax
Jun 8, 2001 12:03 PM
SB97MAX
May 14, 2001 07:29 AM
