Engine making noise when I start it???
Old Feb 7, 2002 | 05:10 AM
Esfooni23's Avatar
Hey
Was wondering if ya'll could help me out in figuring out why my engine makes this noise when I start it... I saw another thread that sounded just like the same problem I have, and it was the starter. Do you think that could be the problem, and that I need to change my starter?
Old Feb 7, 2002 | 06:06 AM
sislen's Avatar
Engine noise when you start
If it sounds like a grinding noise that occurs immediately after releasing the starter key, then your starter needs to be replaced. The noise might last a few seconds. Each time you hear that grinding noise, the starter gear is grinding against your flywheel. So the problem should be fixed within a few months or so. I let my starter grind about 6 months before replacing the starter and my flywheel had a little damage (not much).
I replaced mine last summer (97 Maxima @56k miles). Autozone has lifetime warranty starters for $120. It was very easy to replace. It took about 1.5 hours or so. You might need a torque wrench to torque the bolts connecting the starter to engine.
The Nissan Dealer has a Nissan starter with a 1 year warranty (I think) for around $200-250. If you have the dealer do the labor, it might cost you around $300+.
Old Feb 7, 2002 | 06:15 AM
NmexMAX's Avatar
dot dot dot ...
Re: Engine noise when you start
try greasing it before you replace the whole unit. its on some motorev site, i'll look for the link now.
Old Feb 7, 2002 | 06:16 AM
NmexMAX's Avatar
dot dot dot ...
Re: Re: Engine noise when you start
http://motorvate.ca/
Old Feb 7, 2002 | 08:55 AM
Justin95SE's Avatar
yup
Old Feb 7, 2002 | 12:26 PM
sarmast's Avatar
It sounds like a little high pitched squeal right after you start right? Same thing here, it was the starter. Put in an autozone special and all better.
Old Feb 7, 2002 | 03:25 PM
MDubya
Re: Engine making noise when I start it???
On Mine right after it starts the Lifters knock for a second or two right after it turns over but before the RPM s go to 1100.
Old Feb 7, 2002 | 05:27 PM
pocketrocket's Avatar
I vote we call it: "The Starter Donkey Wheezing Sound"
(if this goes, remember me as the one who pioneered the description. Put me in a sticky
http://forums.maxima.org/showthread....threadid=96300
Old Feb 7, 2002 | 05:30 PM
PRPmax's Avatar
Originally posted by Esfooni23
Hey
Hey man, If it is your starter let me know.. It'll only take 30mins tops! Not hard at all just have to remove your intake.
Hit me up or IM (Puertoroc79).
Later!
Nel
Hondarydr
Dec 30, 2024 06:15 PM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
