Star Headliner ⭐️
Old Apr 17, 2021 | 10:01 PM
dbaray's Avatar
Star Headliner ⭐️
This is my first time ever doing this on my car and I thought I should share it in the forums. I think its cool and I highly recommend any of you to do this to your beautiful maxima as this looks so dope at night! I did this all by myself and I think I did a great job. I have a youtube link for it as I had trouble posting video here. If any of you have questions ill do my best to help 😀.
Old Apr 18, 2021 | 03:22 AM
Rit's Avatar
Rit
Any instructions on where you bought it, hom much did it cost, amd how do you install it ?
THX
Old Apr 18, 2021 | 05:57 AM
dbaray's Avatar
THX
its all done on the same headliner. It took be about 10 hours to perfect every marking and glue the optic fibers to the headliner and I let the glue cure for 2 days. I would not recommend super gluing the fibers because when you super glue the fibers, it can eat away at them as it dries. U can use hot glue or some paste or silicone but don't use a lot just a drop. The main trick is getting the headliner out and back in. Im sure there are instructions on the forums to get it out but basically i just unbolted the door a bit to allow it to open as wide as it could and i didnt have to remove it. I removed all seats to get reupholstered anyway and the center console and parking brake were removed as well and it came out fine. Be careful when you bend it to get out because u can crack it but i didnt crease or crack mine. When i finally put it back in, I took the sunroof door out from the back side near the rear window it comes out with 2 little tabs that unscrew on the top of the brackets that hold the sunroof on. Just slide it out through there and slide it back in. So basically, get the whole headliner back in the same way u took it out, be sure to tape the sunroof to the headliner to not fall (you can remove the tape after its in) then once the headliner is inside put the sunroof door in FIRST! Allow extra strand of optic fiber about 12 inches to go back and forth with out pulling any out and you are good. If you dont have a sunroof it will be easier or if you dont want to put any fibers in the sunroof.
Old Apr 18, 2021 | 06:08 AM
dbaray's Avatar
THX
In total i got the whole module for about $100 on Amazon and 2 cans of paint (dupli color) for about $15 so it cost me about $115. Other places would charge you about $700 - $1000. Mine is a 300 star kit and you can always upgrade to more stars. They go all the way up to 1000 stars. These are the channels that helped guide me so it could help you as well!
Old Apr 18, 2021 | 07:13 AM
Turbobink's Avatar
For a cover charge of about $8, the same effect can be obtained at your local strip-club.
... jus sayin ...
Old Apr 18, 2021 | 07:52 AM
dbaray's Avatar
Originally Posted by turbobink
for a cover charge of about $8, the same effect can be obtained at your local strip-club.
... Jus sayin ...
Will92
Jun 8, 2021 03:35 AM
MoncefA33
Jul 27, 2016 09:05 AM
TonyJr
Apr 17, 2016 08:07 PM
Staggered357
Jun 19, 2015 11:53 AM
TonyJr
Mar 7, 2015 12:26 PM
