Radiator drain
Old Jan 7, 2022 | 12:18 PM
Matrix_MGS893's Avatar
Radiator drain
How do I drain the coolant out of the radiator? I see no kind of drain plug. Do I have to just remove the big hose?
Old Jan 7, 2022 | 03:27 PM
98 i30t 5spd's Avatar
The drain plug is a Phillips head screw. It is on the bottom of the radiator on the driver side.
Old Jan 7, 2022 | 08:38 PM
JvG's Avatar
JvG
You will need to bleed air from the radiator after you fill it. yOu
Raise the front of the car over one foot. Either by parking on a hill, or on jack stands. Jack
The radiator cap needs to be off.
Run the car until it reaches operating temperature so the thermostat opens. Blip the throttle a few times so that the trapped air in the system can burp out. Add more coolant. Repeat a few times till no more coolant can fit in the radiator.
Old Jan 7, 2022 | 11:16 PM
I35GEEK's Avatar
A picture is worth a thousand words. Here is what the drain plug looks like. Be sure to open your radiator cap on the top to allow the coolant drain through the drain plug easily.
Old Jan 8, 2022 | 12:02 PM
Turbobink's Avatar
Just disconnect the lower hose.
azianjiu
Feb 20, 2009 02:43 PM
siren001
Oct 11, 2005 05:37 PM
Neeferea
Jul 9, 2004 04:05 PM
CoolMax
Nov 27, 2001 02:10 PM
