97 maxima se nismo 5speed
You need to use a voltmeter on the battery while it's idling to see what voltage the alternator is charging at. Could be many things, bad replacement alternator out of the box, damaged alternator connector/wiring harness, etc. I worked on one car where I was lazy and assumed the new alternator was bad, turned out the exciter wire in the alternator wiring harness broke in half causing the alternator to not charge
There is a small wiring harness that's just for the alternator, it's possible one of the wires in it has broken. Unplug the little harness from the car, and inspect it closely. A replacement harness from Nissan doesn't cost very much. Have you had your battery tested to know that it's still good?
maxinout93
Jun 10, 2015 11:18 AM
ManualMaxima
Jul 6, 2003 10:15 PM
