running rich code
Old Feb 12, 2002 | 06:10 PM
nigelcmf's Avatar
running rich code
Hi
After I installed my Walbro pump, my idle was running at around 900 rpm instead of the usual 600 or so. No one seems to knoe if that's normal. Anyway, I readjusted the idle using the following steps:
1. disconnect TPS connector
2. start engine (to warm)
3. Adjust idle screw
4. Turn engine off
5. Put TPS connector back
6. Turn ignition to acc
7. Turn screw to right (clockwise) to stop
8. Wait >2 seconds
9. Turn the screw counter clockwise to stop
I restarted the car and kept getting an engine check light. When I check the 7code it gives me code 114 (rich) I turned off the car and reset the ECU again twice! The light has now gone away.
Did I miss/skip a step in here?
Well the check light is gone and idle is at 600-700. Is everything OK now?
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
videomano
Sep 8, 2015 03:28 PM
AT978
Sep 6, 2015 10:31 PM
