Can anyone help??
Old Feb 15, 2002 | 11:04 AM
Tormax's Avatar
Can anyone help??
My trunk wont open with the key. The only way I can open it is to use the remote. I know it's a switch for on and off I've tried it also but it just wont work. i can put the key in but it wont turn either way
Old Feb 15, 2002 | 11:36 AM
SuDZ's Avatar
Re: Can anyone help??
When you flip the switch do you see the latch moving? Is it going all the way over? Anything blocking it?
Check that kind of stuff.
SuDZ
Old Feb 15, 2002 | 11:38 AM
Tormax's Avatar
Okie dokie
Old Feb 15, 2002 | 11:40 AM
Stealth Max's Avatar
Try spraying some WD-40 or graphite oil into the lock. It might just be seized from not using it for a long time. Good luck.
Old Feb 15, 2002 | 11:45 AM
AndyXXL's Avatar
Re: Re: Can anyone help??
Originally posted by Stealth Max
Try spraying some hydrochloric acid into the lock.
Um...are you sure about that Ken?
Old Feb 15, 2002 | 12:08 PM
njmaxseltd's Avatar
Re: Re: Re: Can anyone help??
