engine oil leak stopper
Old Feb 16, 2002 | 01:07 PM
Craig K. Balgobin's Avatar
I have an oil leak from the upper oil pan. To get this fixed it a lot of work because of the location of the upper pan, its gonna be expensive. I was gonna try one of those oil leak stoppers you just poar into the crankcase but im not sure its gonna be safe for my engine?
Old Feb 16, 2002 | 01:50 PM
iwannabmw's Avatar
You're just delaying the inevitable.
Old Feb 16, 2002 | 01:58 PM
Chunger's Avatar
My other car is a Hybrid
The stuff that stops the leak may stop oil from other areas too.
Old Feb 16, 2002 | 03:03 PM
KWheelzSB's Avatar
Originally posted by Chunger
The the stuff that stops the leak may stop oil from other areas too.
I agree - something designed to "plug" an oil leak could also "plug" any of several very tiny pathways the oil must travel through in order to ensure that ALL parts of your engine are properly lubricated. Personally, I wouldn't do it to my own car.
Old Feb 16, 2002 | 03:54 PM
exhip95's Avatar
Re: engine oil leak stopper
Like Steve said, it is inevitable. A gasket replacement sure is a lot less expensive than rebuilding/replacing the engine due to oil starvation. Those leak stoppers can do way more damage than good. If you like your car as much as I like mine you will keep checking the oil and topping it off when its low and repair it properly when you can.
Best Wishes...
Old Feb 16, 2002 | 04:04 PM
exhip95's Avatar
Re: Re: engine oil leak stopper
[QUOTE]Originally posted by exhip95
[B]
Like Steve said, it is inevitable....
Sorry about that iwannabmw, I got you confused with Steve Marsh because you are both Amsoil dealers (your sig).
Old Feb 16, 2002 | 04:15 PM
iwannabmw's Avatar
Re: Re: Re: engine oil leak stopper
[B]
I'll let it slide this time No harm, no foul right?
Old Feb 19, 2002 | 05:55 AM
Steve Marsh's Avatar
I agree with the other members, make the proper repairs, avoid that patch it in a can/bottle stuff! You certainly don't want to screw up your VQ! Best Wishes! 96se auto 164,665 miles (feather like gas pedal acceleration effect!) all Amsoil lubricants/filtration, Redline "Water Wetter" strict maintenance regimen that would drive a dealer insane! Keep us posted
captchaos
Mar 15, 2016 12:18 PM
6spd4dsc
Mar 4, 2016 05:19 PM
kjlouis
Oct 3, 2015 05:29 AM
dcam0326
Sep 7, 2015 07:26 AM
03VQMAX
Sep 5, 2015 03:47 PM
