Plugs AND gap question
Old Feb 16, 2002 | 01:19 PM
nigelcmf's Avatar
Hi
I have been searching around on the org for this information. I have found quite a lot of info but need some clarification to piece it all together.
I will be running turbo at 5-7 lbs boost, should I get 1 step or 2 step colder plugs? My tuner recommends at LEAST 1 step.
So either:
1-step NGK PFR6G-11
2-step NGK PFR7G-11
(platinums)
I have also seen that we should reduce the gap 0.005" for every 50 HP above stock. Is this IN ADDITION to running colder plugs? I believe stock plugs are 0.043", does that sound right?
I have read people recommending BKR6E/7E (coppers) too! So which ones?
Old Feb 16, 2002 | 06:41 PM
nigelcmf's Avatar
bump!
Old Feb 16, 2002 | 06:52 PM
1MAX2NV's Avatar
Stock gap is .044" My car seems to run better when they are gapped to .035". I had iridium plugs before but I'm running 2-step colder NGK coopers now.
Old Feb 16, 2002 | 07:10 PM
vinny1978's Avatar
what did you think about the iridium plugs. Haven't had time to put mine in. plus its too cold here.
Old Feb 16, 2002 | 07:28 PM
ptatohed's Avatar
Licensed to Spell
Re: Plugs AND gap question
Originally posted by nigelcmf
Hi
So either:
1-step NGK PFR6G-11
2-step NGK PFR7G-11
(platinums)
I'm gonna go with the one-step colder NGK PFR6G-11 gapped at 0.40" now that my SC is in. This is per Y2Kevs advice. The plugs arrived yesterday ($8.88 from cortesy -$16 from dealer!). Good luck.
Old Feb 16, 2002 | 09:05 PM
MardiGrasMax's Avatar
Yes my brother, you have seen the light!
Old Feb 17, 2002 | 08:04 AM
nigelcmf's Avatar
Re: Re: Plugs AND gap question
How much boost are you running on your s/c? Is it standard 6psi or small pulley 3.125"?
Old Feb 18, 2002 | 01:48 PM
ptatohed's Avatar
Licensed to Spell
Re: Re: Re: Plugs AND gap question
Stock... for now.
Old Jul 20, 2002 | 03:34 PM
dashingMax's Avatar
Does the NGK PFR6G-11 plugs come pre-gapped at 0.040" or did you change the gap yourself.?
I know the stock PFR5G-11 come pre gapped at 0.044".
I just purchased a set of 1 step colder NGK plugs. DO I need to gap 'em before I install them?
I am running 8psi boost on stock internals...
Thx
Old Jul 20, 2002 | 04:05 PM
Thx
11 is the gap code for NGK, so they are .044"
Old Jul 21, 2002 | 03:49 AM
MaxJag's Avatar
Which ones?
Which NGK's do you recommend for a 96 Auto GLE with frankencar?
This website sells these NGK types: G-Power, Iridium, Laser Platinum, Racing, and VX Platinum.
http://www.clubplug.net/retail_gp_ngk.html
All input is highly appreciatted.
What do you suggest Clee?
Old Jul 22, 2002 | 09:00 AM
ptatohed's Avatar
Licensed to Spell
Thx
They do not come pre-gapped.
9aj9
Apr 5, 2020 12:11 AM
knight_yyz
Nov 6, 2015 02:34 PM
chernandez1278
Sep 16, 2015 01:18 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
