Flywheels on autos?
Old Feb 19, 2002 | 09:20 PM
SoccrZ's Avatar
Flywheels on autos?
I was talking to a guy tonight that said it was possible to install a flywheel on an automatic transmission. Is this true, because I thought they were only for manual transmissions? Can anyone answer this question? Thanks.
Old Feb 19, 2002 | 11:31 PM
sbslacker's Avatar
Re: Flywheels on autos?
Automatic transmissions do contain a flywheel.
Old Feb 19, 2002 | 11:37 PM
Nismo's Avatar
Re: Re: Flywheels on autos?
and its stuck on the torque convertor
Old Feb 19, 2002 | 11:43 PM
Xtreme5053's Avatar
Re: Re: Re: Flywheels on autos?
As quoted from Stillen catalogue...
With reduced weight (stock is 17.5lbs., this beauty weighs in at just over 13lbs.), less power is needed to overcome Flywheel inertia. The result is a quicker revving motor. The Maxima's stock Flywheel is essentially the automatic's torque converter plate with weights added and is not ideally suited for performance applications. Uses the factory timing ring/gear from stock unit.
Applications:
95-01 Nissan Maxima (Manual Transmissions Only ), Part #451065
96-99 Infiniti I30 (Manual Transmissions Only ), Part #451065
This is the 2002 catalogue and was mailed to me Feb 7, 2002
Old Feb 20, 2002 | 05:57 AM
Tubbed'65's Avatar
Its called a flexplate, not a flywheel. 2 totally different things.
Old Feb 20, 2002 | 06:12 AM
AznStevie's Avatar
uh..... have you seen the flywheel on a auto? hehe...it's really really light compare to 5 speed... hehe... why change it?
AaronL
Aug 8, 2020 10:31 AM
hayne
Oct 5, 2015 11:53 AM
Maximeltman
Sep 28, 2015 07:19 PM
dshinn
Sep 26, 2015 08:07 PM
