Are '97 and '99 Y-pipes compatible? >>
Old Feb 20, 2002 | 05:15 AM
Albertt's Avatar
I need to know if it is possible for me to swap on a '99 y-pipe to my '97. My current y-pipe has a puncture in the flex section due to road debris...
Al
Old Feb 20, 2002 | 09:21 AM
Albertt's Avatar
Comedy >>
Bump and rant:
I find it hilarious that there can be a thousand replies to a post about who's HID kit is more blue and more purple, and which 1157 bulb best matches the headlamps, while serious questions, can be left untouched.
Old Feb 20, 2002 | 09:47 AM
araffio's Avatar
Re: Are '97 and '99 Y-pipes compatible? >>
Al
Not positive, but I think they are interchangable. I think you'd have a problem going from a 99 to a 95-96, but I think you'll be ok. Check warpspeedperformance.com and see if they sell different y-pipes for 97 Maximas and 99 Maximas. I'm pretty sure they sell the same one for both.
-Tony
Old Feb 20, 2002 | 10:16 AM
ejj's Avatar
ejj
Is the 99 Fed Spec or Cali?
If its fed spec, then yes, they are interchangable. O2 sensors are the same and so are flange/bolt positions and sizes.
If the 99 is Cal spec, then no, they are totally different pipes.
P.S. -- I've put a 99 Fed Spec Y-pipe on a 97. No problems.
Old Feb 20, 2002 | 10:19 AM
MDr's Avatar
MDr
Cattman's using one part number for 95 to 99 y-pipe.
Old Feb 20, 2002 | 10:23 AM
ejj's Avatar
ejj
Again, be careful. Fed Spec 99's and Cal spec 99's have a different part number.
To tell if you're fed spec look in front of the valve cover..if you have 2 plugs, fed, if you have 4 plugs, cal.
Old Feb 20, 2002 | 11:34 AM
xHypex's Avatar
Re: Comedy >>
Bump and rant:
Albertt I agree that MANY informational posts/questions get passed over in favor of which bulb or intake to buy. It seems that unless you're doing a SC or turbo project you're just not important enough
ejj what plugs are you talking about on the valve cover?
-hype
Old Feb 20, 2002 | 11:40 AM
ejj's Avatar
ejj
Re: Re: Comedy >>
-hype
http://www.cattman.com/images/produc...ec-diagram.jpg
Quickywd01
Sep 21, 2016 09:36 PM
lrb6805
Sep 17, 2015 04:49 PM
mix master
Sep 7, 2015 08:28 PM
mix master
Sep 4, 2015 05:50 PM
