Removing the resonator.
Old Feb 26, 2002 | 09:04 PM
Bill Wattison's Avatar
Is there a HOWTO for removing the resonator on a 4th gen maxima? I understand it will reap no gains for performance, but I would like to see how the additional noise will affect me throughout my long drives and such, before I install intake and a y-pipe.
Through search I found a HOWTO for the 3rd generation maxima; how different is the removal of the resonator for the 3rd gen compared to the 4th gen?
Thanks in advance for the help.
Old Feb 26, 2002 | 09:42 PM
Maxima97GLE's Avatar
I have no clue about the how to since i got the whole B-pipe replaced but you'll love the sound and you'll gain a lot of ground clearance
Old Feb 26, 2002 | 09:46 PM
Swafford98's Avatar
need to be clear on which resonator you are talking about
..intake resonator
..exhaust resonator
Old Feb 26, 2002 | 09:49 PM
The intake resonator, I'm assuming it is easier.
..intake resonator
..exhaust resonator
Old Feb 26, 2002 | 10:02 PM
ok in this case... if your talking about that big black box in front of your throttlebody... you'll really love the sound. Plus you'll feel a lil more power... i know i did... if you want a pic of how mine looks i'll send you an email
Old Feb 26, 2002 | 10:26 PM
Did you remove the intake resonator yourself? I can't find any removal instructions so I would appreciate it if you could tell me how you did it.
Old Feb 26, 2002 | 10:39 PM
Nismo's Avatar
once you remove it then you will either have to buy to PR upper tube or fabricate your own tube to connect the 2 hoses
Old Feb 27, 2002 | 05:12 AM
ejj's Avatar
ejj
Bill -
Its really quite simple. There are 3 vacume hoses running into the resonator. Remove them. Pull the resonator off the throttle body (there may be a clamp on it), then pull it off the MAS.
Replace it with an upper PR CAI Piece or something else and re-hook up the vacume hoses.
Note: If you use the PR piece, there is a hole for the intake air temp sensor..that is located in the piping going to the stock air box.
http://www.rit.edu/~ejjfac/maxima/hybrid_intake.jpg
Old Feb 27, 2002 | 05:21 AM
ne max's Avatar
anyone have the upper tube with the stock airbox (not cone filter) at the end? if so how does it sound and did you feel any gains?
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
