Which BRAKE fluid?
Old Feb 27, 2002 | 11:39 AM
Mikesburn's Avatar
Which BRAKE fluid?
Some people say that it doesn't matter wich brake fluid you'll put into your system. However, someone told me that there is a special FLUID, which comes in 2 bottles and costs around 20 bucks is needed.
Is it worth buying this one or just spend 4 bucks on the reg. fluid at Kragen store???
Old Feb 27, 2002 | 11:46 AM
Jeff92se's Avatar
I'm needing a caw
http://google.yahoo.com/bin/query?p=...ison&hc=0&hs=0
Old Feb 27, 2002 | 11:50 AM
SuDZ's Avatar
I believe you can get some of the upgraded fluid fomr Pheuong at www.eatricezone.com under the brakes section.
SuDZ
Old Feb 27, 2002 | 12:01 PM
iwannabmw's Avatar
I use ATE Super Blue in my car. I didn't know it wasn't DOT approved because of the color though. Oh well, I'm happy as long as it meets or exceeds the requirements. It certainly holds up to the heat generated on the track.
Old Feb 27, 2002 | 12:16 PM
SuDZ's Avatar
Huh... I thought it was some kind of regulation that it had to be DOT approved. Guess not. Are there many out there non- DOT approved?
SuDZ
Old Feb 27, 2002 | 12:24 PM
KWheelzSB's Avatar
ATE Super Blue, too!
Me too - got it from Phuong @ www.eatricezone.com -very high quality stuff & I recommend shopping w/ him.
-K-
Old Feb 27, 2002 | 12:47 PM
Mikesburn's Avatar
-K-
Yeh, he's nice guy, I'll call him about the fluid, thanx
Old Feb 27, 2002 | 01:56 PM
clee130's Avatar
I bought brake fluid from Phoung. Never used it.
http://forums.maxima.org/showthread.php?threadid=100008
Old Feb 27, 2002 | 02:02 PM
iwannabmw's Avatar
SuDZ
Well, I really have no idea if it actually is DOT approved or not. To be used on the road legally it needs DOT approval. The can says "Racing" brake fluid on it. The can also goes on to says it surpasses DOT 3 and 4 standards as well as the German standard, but it does not specifically say it IS DOT approved. My post was referring to the link which Jeff provided. Through there I found this:
My conclusion: ATE Type 200 and Super Blue are not only the cheapest of the performance brake fluids, they are also the cheapest per degree of boil protection, and have a very high 6-month BP estimate. In addition you can alternate with each change and the color difference will tell you when you're done. [Note that ATE Blue is not DOT-approved because of the color.] ATE and some of the higher-performance fluids are available from ogracing.com.
I'm happy with it either way and won't lose any sleep over it.
Old Feb 27, 2002 | 02:09 PM
Shadow's Avatar
I use Motul 600, expensive stuff, but not really worth it.
Old Feb 27, 2002 | 02:28 PM
xHypex's Avatar
I'm running Ford Hi Temp Dot4 fluid and it's been great. I got it because it's a lot cheaper than Motul and it's available at any Ford dealer. However, last time I tried to buy it at a dealership they said they don't make it anymore though It also clearly states on the label the fluid is to be used for the Ford Focus
-hype
Old Feb 27, 2002 | 04:04 PM
iwannabmw's Avatar
-hype
Real intelligent dealership
Old Feb 27, 2002 | 04:08 PM
SuDZ's Avatar
Maybe they have realized the Focus is too ugly and will discontinue making it.
SuDZ
Old Feb 27, 2002 | 04:18 PM
Vinipux's Avatar
hey man, you're online right now,
give me a call
- edit -
Vinipux
(Whoa there ... don't be posting your telephone number on a public forum. Please use PM for that!)
Old Feb 27, 2002 | 04:57 PM
1MAX2NV's Avatar
Valvoline Synthetic Brake Fluid. Great stuff for the price. The spec on it is pretty close to racing type fluid ie. ATE or Motul. http://www.valvoline.com/
Just compare the wet/dry boiling point and you will know what I'm talking about.
http://www.valvoline.com/pages/produ...asp?Product=51
Old Feb 27, 2002 | 08:46 PM
got rice?'s Avatar
Re: ATE Super Blue, too!
-K-
every week I see a new spelling of my name
I don't know why it was mentioned incorrectly, but the ATE Super Blue is DOT 4 rated.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
