Weapon R coilovers
Weapon R coilovers
ok i have the Weapon R Coilovers on the way in the mail...i am going to replace my rear struts but i do not know what ones to buy.....i dont want to spend a lot of money on rear struts but i want something that will work well with the weapon r's. does anyone have any suggestions...i am planning on spending around 150-180 for struts if that is possible.....thanx guys....
website links would be great!!!!!
Re: Weapon R coilovers
it's really worthless for me to post, but i am riding on Koni Yellow's with Weapon R's coilovers and it's not a bad ride.. might be an idea to save up and wait.. i just need to figure out what setting to put these struts on.
by the way, the Weapon R's sit low and are noisy.
Re: Re: Weapon R coilovers
and y si it worthless for you to post?????
if you are going to be low then you need a very good strut to support that and you have no chance of meeting your pricerange. you need either the koni or the KYB-AGX because when you go low you need a really strong strut or you'll just blow them.
Jason, I'm almost sure that it's the Strut Bearings...
high
ok i dont suggest getting tockikos they suck withthe coilover setup believe me i have them i am switching to konis pawn told me thay are a better ride than what i have but i sit lowwwwwwwwwwwwwwwww
http://www.geocities.com/gacerveza/G...?1012733982176
Re: high
Originally posted by hockeyghst
what kind of konis will do the job???? and where can i prder them online at?????
airbags.. custom kit would be the only thing to satisfy me unless alex (max8mycash) makes a new kit that sits the car down a hell of a lot lower then the first kit. i have weapon Rs and koni yellows and they arent at there lowest point, they are already sitting at the lowest point that the previous air kit i owned was at..
mitch, whatever is causing this HORRIFIC clunking, it needs to stop.. i get weird looks from people when i turn my wheel in a parking lot.
you need to replace your upper front strut bearings to make that loud clunk noise go away. i had the same problem with my gc its like 30 bux for a fricken piece of plastic at the dealer. o yea hockeyghst if u plan on lowering yur car you need to replace your struts with koni or the agx cause if you dont you will be bouncing everywhere trust me on that one
the funny thing is, his car litterally sits that low in person. I was driving behind him on the way up to the Woodbury meet a while back and i thought his car would skip off the road cause it was bouncing so much. Guess its the Tokicos!
Ant
Ant
besides custommaxima.com where can i find agx or koni struts??? and what kind of konis do i need???? the konis yellows???
NewMax03
Oct 7, 2015 08:27 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
