Is this how they always do alignments
Old Mar 5, 2002 | 10:07 PM
Mad Dhan's Avatar
http://community.webshots.com/photo/...32589525mbjAng
here is the print out of the alignment i got today, do they always leave stuff in the red like that or should i go back to them?
Old Mar 6, 2002 | 06:00 AM
emoore924's Avatar
looks fine to me
This is a normal spec sheet from NTB or something like that.
Look for asterisks in the "after" column if you're looking for problems. There shouldn't be any. If there are asterisks, the "after" is out of the range as listed to the right of the readings.
Old Mar 6, 2002 | 06:12 AM
BEJAY1's Avatar
Conecarver
Number's aren't that far off. Looks like they pulled the right toe back in a bit. Car should track more straight now. I only worry bout the camber and toe specs. Don't think those other numbers matter. Anybody else?
Old Mar 6, 2002 | 08:47 AM
sil SE's Avatar
after lowering, should i go to my dealer to do an alignment? or would they say something stupid cuz i changed the suspension
Old Mar 6, 2002 | 08:53 AM
BlkStnValyMaxima's Avatar
After lowering, you should wait a week or 2 for the springs to settle, then get an alignment. If you go to the dealer, I'm sure they're going to say something stupid but they probably will do it without much hastle. There are plenty of other places that do alignments as well.
Old Mar 6, 2002 | 11:39 AM
Eric L.'s Avatar
The only thing that is factory adjustable in terms of alignment on 4th gens is front toe. From your picture, it looks like they adjusted that to spec. So, everything looks to be okay.
Old Mar 6, 2002 | 12:53 PM
SuDZ's Avatar
You usually wont get an a perfect one anyway. But if it is fairly close you will be all set.
SuDZ
NewMax03
Oct 7, 2015 08:27 AM
06maxima55
Sep 28, 2015 04:29 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
ivorton23
Sep 26, 2015 09:47 AM
