clear coat sratches
Old Mar 9, 2002 | 07:59 AM
lefty
clear coat sratches
When I purchased my used max, they attempted to buff down the car.
HOwever, when I took delivery, I noticed massive kinda cloudy swirl marks on the top of the trunk, as if they scrathed the clear coat or something.
It is kinda grey looking now. I tried to rebuff it but it did not work..What are my options?
Kyle
Old Mar 9, 2002 | 09:37 AM
Str8ridin's Avatar
Re: clear coat sratches
Kyle
Clear coat scratches are easy to fix....but I seriously recommend a pro to do it for you. Most of the swirl marks and even deep clear coat scratches can be removed with a wetsander. Again, take it to a body shop or detail shop and see what they can do.
I had something with my car on the trunk and side...like someone took sanpaper and firmly pressed and swirled it. But the wetsanding took care off that. Just make sure you keep taht area polished and waxed thereafter.
Old Mar 9, 2002 | 11:27 AM
lefty
Re: Re: clear coat sratches
Thanks That is what I thought. I love your rear...your Max that is...I just got inspired to shave my emblems and clear my tails next week.
Kyle
Old Mar 9, 2002 | 01:55 PM
WasabiMax
I had the same problem and a friend of mine gave me a few suggestions that worked really well.
1. Use 2000 grit 3M Wet/Dry sandpaper and wet sand the swirl mark using LOTS of water. Use VERY light pressure and be patient. I spent about 1-2 min very, very lightly sanding my swirl mark (about 4 inches in diameter).
2. Dry the area. Then use 3M Microfinishing Rubbing Compound. You can use a buffer but I just used a clean, soft terry cloth and buffed the spot by hand. Use light/medium pressure at first, then gradually apply less and less pressure.
3. The spot should now look pretty good. I finished it off with some 3M Polish and the swirl mark is completely gone and my paint is as smooth as glass. My friend swore by 3M products and now, so do I.
IF the swirl mark is just that, a swirl mark and NOT worn completely to the metal, the steps above should work. I followed my friend's advice and I honestly can't tell where the original swirl spot was.
Good Luck.
Old Mar 9, 2002 | 02:33 PM
Swafford98's Avatar
2. Then use some BuffFlex. A sandpaper , but soft enough that you can not feel by touch. Feels like you are running your hand across a piece pf paper. Again.. VERY lightly
3. Dry the area. Then use 3M Microfinishing Rubbing Compound. Use light/medium pressure at first, then gradually apply less and less pressure.
4. Now use 3M SWIRL remover
this is correct, modified a little. The reason you have that hazy looking spot is where some has already tried to wetsand it and the did not buff it out all the way. the BuffFlex smooths out the area that has been wetsanded. REMEMBER to use water with all of the sandpaper products. DO NOT just start sanding with out using water then it will look really bad.
Old Mar 9, 2002 | 05:29 PM
White96MaxSE's Avatar
These all sound like good tips for scratches on clearcoat.
I might mention that Mequiar's now sells a product called Scratch-X, a fine Scratch and Swirl Remover.
It comes in a 7 Ounce black tube with a big red "X" on it.
It advertises as Clear Coat Safe;
Safely removes:
Light Sratches and Swirls
Oxidation and Blemishes
Bonded Contaminants
It says if Scratch-X cannot remove a scratch or blemish, only machine applied professional formulas can do the job.
I have purchased this tube, but not tried it yet.
Anybody have anything good or bad to say about this product?
Thanks,
White96MaxSE
Old Aug 11, 2002 | 06:12 PM
MaxSpeedSE's Avatar
Thanks,
White96MaxSE
Anyone know?
Old Aug 11, 2002 | 07:15 PM
NickStam's Avatar
didn't you look over the car before you signed the papers? i wouldn't have taken it off the lot.
Old Aug 11, 2002 | 07:34 PM
kmax's Avatar
Originally posted by MaxSpeedSE
Anyone know?
I guess you mean Scratch-X. I have it and use it and can say it's works well. It's a part of my arsenal.
Old Aug 11, 2002 | 08:30 PM
MaxSpeedSE's Avatar
Where can it be bought at, discount auto parts, pep boys ?
-Chri§
Old Aug 11, 2002 | 08:33 PM
Vyrus's Avatar
-Chri§
Advanced Autoparts, Pep Boys, Autozone, Wal-Mart.
-Cyrus
Apr 16, 2020 05:15 AM
Fbana41
Aug 29, 2016 12:18 PM
uttadms31
Sep 30, 2015 05:24 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
