i need a decoder ring!
Old Mar 11, 2002 | 10:05 PM
j-95G's Avatar
has anyone seen that darn check engine light decoder around here?? it seems to disappear every time i need it...
anyway, i got a 34 and an 86 from my light yesterday. someone wanna run those numbers for me and let me know the bad news?! PLEASE!!
'prociate it!!
Old Mar 11, 2002 | 11:15 PM
JAIMECBR900's Avatar
Re: i need a decoder ring!
'prociate it!!
You gotta do a search, and I don't remember on which one but there is a thread in there that gives an alternate website to look at the code table. Good luck. BTW you will probably need more numbers to decipher the fault code. I believe the 34 is probably 0304 which is the knock sensor, but I don't remember what 0806 is.
Old Mar 11, 2002 | 11:21 PM
DCmax's Avatar
Knock Sensor 0304
EVAP canister purge control valve/solenoid valve 0806
Bookmark this: http://vbxmaxima.8m.com/ecudecoder.html
Old Mar 12, 2002 | 05:11 PM
exhip95's Avatar
'prociate it!!
I hate having to disagree with the decoder but in the Haynes manual the 0806 code indicates "fuel injection system lean or rich (left bank)". This would be the front bank. Could someone with a Chilton confirm this so I won't sound like an A$$.
If you get the CEL again you may also have 0414 or 0415 along with 0806. Both of these are related to a rich or lean condition from the O2 sensor for the same bank.
Sorry DCmax...
Old Mar 12, 2002 | 06:12 PM
kmax's Avatar
Re: Re: i need a decoder ring!
Sorry DCmax...
I have a Chilton and it dosen't list code 0806. It does list 0304 as a knock sensor problem. the probable causes are: 1) Harness or connectors are shorted. 2) knock sensor.
Old Mar 12, 2002 | 10:09 PM
j-95G's Avatar
Re: Re: Re: i need a decoder ring!
hmmm...i am noticing that my air/fuel ratio gauge sits on lean 90% of the time. i did actually tap into the front oxygen sensor, so, this may be true. i'll try tapping the rear sensor tomorrow and see if it reads the same. could it be a problem with the injectors running lean or would it be the oxygen sensor??? any instructions on how to check the 02 sensor???????
maxfever1987
Nov 19, 2016 08:01 PM
Pied
Sep 26, 2015 03:29 PM
msellas
Sep 23, 2015 09:16 PM
DBear
Sep 14, 2015 08:33 PM
95Maxi
Aug 25, 2015 08:01 PM
