I called the dealer about a Knock Sensor, and the parts guy says...
Old Mar 12, 2002 | 11:07 AM
FLO_BOY's Avatar
"Who's telling you its the Knock Sensor, those are often dummy codes, and you should check your O2 Sensors"
Any thoughts on that one????
I've already replaced my right O2 Sensor, and after noticing a loss in power, I naturally assumed that my KS was KO'd.
And, after checking the .org for so long, it seems to be a fairly
common issue (group deal anyone?)...and I currently have 100K miles on my car, so, maybe it was just its time...
thanks everyone!
Old Mar 12, 2002 | 11:20 AM
mzmtg's Avatar
Minister of Silly Walks
Tell him just be quiet and order you a knock sensor.
Toolrocks's Avatar
yeah, it may be time. I recently relaced mine at 120,000 Did you pull your codes? You shouldn't just replace it unless the ECU tells you it's bad. Also, if you have a Haynes manual, I think they tell you how to check one w/ a multimeter. Good luck.
Old Mar 12, 2002 | 11:27 AM
FLO_BOY's Avatar
Yes, I've pulled the codes myself and received NUMEROUS KS codes, the occasional O2 code, and once a Mass Air Flow Code! I've been having intermittent problems for quite some time...I cleaned my Throttle Body, and the problem is less pronounced, but, still rears its ugly head once in a while
Thanks!!!
Old Mar 12, 2002 | 11:30 AM
jay_x's Avatar
A bad o2 sensor can trip the ks code. Since you already replaced the problem o2 sensor, you may legitamitly have a bad knock sensor.
Old Mar 12, 2002 | 11:44 AM
Toolrocks's Avatar
Easy there killer, after re-reading your original post; maybe the Nissan guy thinks that since the K.S. doesn't trip the CEL it's not a legitimate problem? Did you ask him what he meant? Do you get gas from the same station and you do run 92 or higher right? If you keep getting the K.S. code you should replace it - don't think about what the Nissan guy says. I'm sure you've read the other "testimonials" on this site where people praise replacing the K.S. Good luck and hope your car feels better soon.
Old Mar 12, 2002 | 11:47 AM
FLO_BOY's Avatar
couple things:
1) I ALWAYS run 92 or higher...normally 94...and I will often drive around until I find it!
2) Yes, I keep getting the KS code...
3) Thanks for the advice...much appreciated!
Old Mar 12, 2002 | 01:03 PM
njmaxseltd's Avatar
[Saying to myself]
"Self, do you think the parts counter guy at Nissan is a trained auto tech?"
[/Saying to myself}
[Self answering back]
NOPE
[/Self answering back]
Old Mar 12, 2002 | 02:36 PM
Ravq's Avatar
Originally posted by njmaxseltd
[Saying to myself]
[/Saying to myself}
NOPE
Same thing I was thinking.
Old Mar 12, 2002 | 02:48 PM
Riot^'s Avatar
group deal
Can soeone with a "hook up" start one of these???
I am sure we can get 20 people off this board that need a bloody KS.
Old Mar 12, 2002 | 03:03 PM
Jeff92se's Avatar
I'm needing a caw
You could try extreme Nissan. They are having killer deals until the end of March. Apparently they are closing their doors March/end/2002'
Old Mar 12, 2002 | 03:28 PM
sp6040's Avatar
ks
id be on a group deal for knock sensor.my car is sick.
Old Mar 12, 2002 | 04:02 PM
ny96max's Avatar
My car has been spittin out the KS code for a yr now. My mechanic told me a while back when i had all of the o2 sensors changed and the 60k tune-up that sometimes the computer throws a false code. And now that my check engine light is on and off litterally everyday i think its time for that knock sensor. Thats the only code i get when i check the ecu. unless i missed something.
Figures today my car starts hesitating again like it did when one of my old coil packs went bad guess ill buy another one and hopefully solve the problem for another yr, lol.
Ant
Old Mar 19, 2002 | 05:11 PM
MaxedOut97SE
Yes but that does make sense.
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
