Water Probs with Place Racing CAI?
Old Mar 13, 2002 | 10:01 AM
tshawytscha's Avatar
I have heard that the location of the Place Racing Cold Air Intake inlet can cause water to enter your engine. Is this true? I live in an area that receives 140-160 inches of rain per year, so this is obviously a big concern for me. Would I be better off using the K&N style intake?
Old Mar 13, 2002 | 10:12 AM
buss95max's Avatar
the cai puts the filter next to ur left front wheel. if you have a wheel well cover, water shouldnt come in contact with ur filter. if you're really worried about your filter sucking in water, just get a short ram. Or you can get a PR cai and just put the upper piece(ala short ram), and slap on the bottom piece when it stops raining so much....
Old Mar 13, 2002 | 10:45 AM
asianmotorsports2000's Avatar
Re: Water Probs with Place Racing CAI?
I have had mine for almost 2 years. I live in Florida and have dropped the car 2" on springs... NEVER and I REPEAT NEVER have I had any problems with water.... Just remember not to drive through the pool...
Old Mar 13, 2002 | 11:40 AM
jargoone's Avatar
Though I don't have an intake, I want one and have wondered about this too. I think the only concern is driving in enough water to completely cover the filter, so the engine has to pull in water rather than air. If that happens, I think you would have bigger problems, like not drowning. Even this case can be avoided with a bypass valve.
To my knowledge, the filter getting water on it will harm nothing. Someone please correct me if I'm wrong.
Old Mar 13, 2002 | 11:49 PM
KWheelzSB's Avatar
AEM air bypass valve
It really takes a serious level of innattention to cause an H2O-related CAI catastrophic engine failure. (Don't get me wrong - people have done it).
"The minute you idiot-proof a thing, the world invents a bigger idiot." -unknown
You'd have to be well into the rev range or WOT going through standing water (deep puddles) to do it. If you have a CAI & you're not a complete idiot (I'll assume you're not), you know this is a situation to avoid. If you approach standing water, low revs (or off the gas altogether if possible) is what you're shooting for.
If you want peace of mind, just install the AEM air bypass valve & you'll have nothing to worry about.
http://www.aempower.com/induction.htm
(It says "for use only w/ AEM induction systems," but that's just for liability reasons - they can't guarantee the valve's effectiveness when paired with non-AEM engineered products - that doesn't mean it isn't actually effective with other companies' intakes). The valve can be purchased separately.
Old Mar 14, 2002 | 09:27 AM
Asian_N02's Avatar
no water problems here and I've had mine for over a year now...driving in Colorado snow and rain
Old Mar 14, 2002 | 12:24 PM
Synki's Avatar
You will not have any problems with the CAI in rain or snow. Unless you drive through 5" worth of water, you will be fine.
BTW-AEM had a recall about their bypass valves & not fully working & it actually had let water by. Its probably been fixed but i have yet to seen anyone use it with their CAI.
Old Mar 14, 2002 | 12:35 PM
DaEnigma's Avatar
I would think it will need to be deeper than 5"... I would say it would have to me more like 8-11" (just measure from the ground to the filter) and even then it would not totally submerge the filter...
I live here in Oregon which does not get the heavy down pours like in CO but we get constant rain (~1-3" a week) for like 5-7 months and I have never had a problem, but I have backed out of a flooded street that was ~7" deep once I noticed it was a pond and I was only going ~5mph.
As usual this is IMHO
Old Mar 14, 2002 | 12:41 PM
Synki's Avatar
The more water, the more it will splash.
Old Mar 14, 2002 | 10:00 PM
JAIMECBR900's Avatar
I have a PR CAI and have an AEM bypass valve. No probs installing except had to do away with one of the rubber connectors that came originally in the CAI and put the AEM valve in it's place. As it has been said time after time, water is not a real issue but if you are worried then install a bypass valve and worry about something else.
Old Mar 14, 2002 | 11:23 PM
KWheelzSB's Avatar
Yes, I was aware, but didn't mention because they have corrected the problem with a new design. As I understood, the problem with the original design was not that it was allowing water to pass through, but that one or more of the rubberized flaps on the valve were potentially able to detatch from the valve and become lodged in the intake under certain circumstances.
If you're shopping for an AEM air-bypass valve, verify from AEM what the new part # is, so you can be sure you don't get the faulty valve.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
Sep 27, 2015 08:37 AM
