o2 sensor Front FR?
Old Nov 20, 2000 | 10:20 PM
95GreenGLE's Avatar
i checked the code on the ECU myself and got 0901... which is "o2 sensor front fr".. this came on when i put on the K&N filter and adaptor. no.. i know there is a mass air sensor.. is this o2 sensor the little sensor that was screwed into the factory airbox that i had to leave wire-tied up in the engine compartment b/c i dont have the factory airbox anymore? any help would be great.
Old Nov 21, 2000 | 05:26 AM
Jeff K's Avatar
This should help..>
The wire that is next to the Mass Air sensor is your temperature sensor which should be located somewhere in
the intakes air flow. In the picture below I had mine in the rubber neck of the K&N filter.
<IMG SRC=http://integra.vtec.net/geeser/megamax/images/mm_intake_1.jpg>
The front O2 sensors are located in the Y-pipe, it directly under the motor. You would need a 7/8 combo wrench to remove the sensor, I'm not sure which one would be bad. If you need
further info on how to remove them just e-mail me.
Otherwise the dealer will be able to take car of the sensors.
rbuswell
Nov 12, 2016 04:11 PM
vingodine
45
May 21, 2016 12:46 PM
Slamrod
Sep 3, 2015 07:38 PM
homeyclaus
Sep 3, 2015 06:15 PM
