Paint problems
I have a similar problem on my '99 SE. I actually have cracking beneath the clearcoat. It's really weird. The paint feels smooth, but I have 3 small cracking areas the size of a pea on my hood. I talked to a body shop and they said the only way to fix the problem is to sand the area deep enough to remove the cracking paint and then repaint it.
Originally posted by 95emeraldgxe
www.paintscratch.com
dont think they got a warranty on the paint........i read on a post a few weeks back about how canada dealerships offer sum kinda paint warranty - but its probabaly not available in NY
YES, they have a warranty on paint. It should be covered under the "Basic Coverage" portion of the 3yr/36k mi warranty.
The warranty covers any repairs needed to correct defects in materials or workmanship of all parts and components of each new Nissan vehicle supplied by Nissan except for the exclusions or items listed under or as indicated below.
Damage, Failures or Corrosion from Environmental Conditions - This warranty does not cover damage, failures or corrosion resulting form stone chipping, chemical fallout, tree sap, salt, hail, windstorm, lightning, flood or other environmental conditions.
My sis in law had a similar problem with her 2k Pathfinder. She called Nissan USA and received a vague answer, only to tell her to take it to the dealership for inspection to see if the defect qualified for warranty coverage. She did that and it took three different dealerships to finally get it fixed. The first two didn't even want to deal with it. The last dealership had its own bodyshop so that helped. However, her new car warranty was still in effect. Your 98 is past the coverage period. If you have an extended warranty/service contract, you are SOL too because they do not cover paint/cosmetics. Sorry!
yes - their touchup paint matches up very nicely - well worth the money
Originally posted by WasabiMax
95emeraldgxe, does paintscratch.com's paint match better than OEM Nissan touch up paint? I tried using Nissan touch up paint for my pearl white color and the touch up paint dries almost a grey color. I went to paintscratch.com's site and they say they match the OEM color. I wonder if they mean the OEM paint on my car or the OEM touch up paint.
Re:Wasabi MAX
Wasabi, I have the same exact problem on my 97SE which is black, I have 3 on the trunk and 1 on the hood. They are pea size and look like little cracks but are smooth weird, I thought my Max was the only one with that problem.
doctorpullit
Apr 23, 2017 05:35 AM
Hdnseek
Sep 9, 2015 05:55 AM
. Atleast it gives you achance to get a carbon fiber hood,
