IS300 Rims
Old Mar 21, 2002 | 04:03 PM
JPMontoya's Avatar
IS300 Rims
Will the IS 300 rims fit on a Max??
What is the offset on the Max?
I know the bolt pattern is 5, but need to know the degree of separation between the bolts, any know this? (For an even separation it's 360/5 = 72)
The reason being, I might be able to get the IS300 rims for approx $300 used for about 3 months thru a friend that's getting new rims just because.
Old Mar 21, 2002 | 04:09 PM
mzmtg's Avatar
Minister of Silly Walks
Yeah, dey be fittin'
Also, bolt patterns are not measured by degrees of seperation. All 5 lug rims will have 72 degrees between lugs.
Ok, if you numbers the lugs 1 through 5...they measure the distance in millimeters between lugs 1 and 3. Two lugs not right next to each other.
So the max has 5-114mm pattern. 5 lugs with 114mm between the lugs not next to each other.
...if that is making sense.
Old Mar 21, 2002 | 06:57 PM
FameMax's Avatar
Re: IS300 Rims
Hey just to anyone how will bad mouth u about getting lexus rims, i'd just like to say Is300 rims r sick. They r some of the sweetest stock rims i have ever seen, i think they'd fit, and ur getting a good deal, $300 for a set, u could sell em for double that!
Old Mar 21, 2002 | 09:53 PM
Asian_N02's Avatar
i have to agree...IS300 rims definitely look good on a Maxima...somebody here has already done it...!
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
