rim and tire weight?
Old Mar 21, 2002 | 04:26 PM
mark w chrzanow's Avatar
what is a good rims and tire weight?
The stock saw blade rims are 40lbs with tires and people are saying
this is bad.
The weight of my chrome rims are 51 lbs
I called about the koing tantrum and it is 19 lbs for the rim alone
is this good?
thanks mark
Old Mar 21, 2002 | 04:31 PM
95emeraldgxe's Avatar
19 LBs for a rim is good
Old Mar 21, 2002 | 04:38 PM
sorry - i forgot to ask what size the rims are - i assumed your talking about 17's
Old Mar 21, 2002 | 05:08 PM
yes 17 sorry
Old Mar 21, 2002 | 07:55 PM
sil SE's Avatar
does anyone agree with my reasoning...er..rationalization..that 5th gen wheels are heavy, but with the weight taken off by replacing a stock y pipe, youll sort of even out.?
i understand that wheels are where acceleration will lose because of rotating mass and stuff and not weight on the body, but. im tryin to rationalize getting 5th gens, when i do.
Old Mar 21, 2002 | 08:10 PM
BEJAY1's Avatar
Conecarver
19lb wheels are good.
Every 1 lb saved on sprung weight (wheels, tires, lugs, rotors, etc) = approx 8lbs static weight.
Y pipe weight savings would be minimal - about the same as wearing down your tire rubber a bit.
Saving 3lbs per wheel x 4 x 8 = 96lbs static saved
Old Mar 21, 2002 | 08:12 PM
Nealoc187's Avatar
SLOW
No. Rotational weight has much more of an effect on acceleration than static weight like the Y-pipe. If you are trying to save weight and improve acceleration, you can't rationalize 5th gen wheels on a 4th gen.
Old Mar 21, 2002 | 08:37 PM
BEJAY1's Avatar
Conecarver
Hey Nealoc187. I just removed my snow rims/tires & weighed em. 42lbs a set. Tried out my new Kosei's last weekend - 40.75lbs per set. That's another 40lbs static less than the dyno day.
Old Mar 22, 2002 | 12:45 PM
chris j vurnis's Avatar
You can try the website:
www.wheelweights.net
They have the weight of just about every kind of wheel on the
market.
Later..
Old Mar 22, 2002 | 12:48 PM
sil SE's Avatar
guess i wont be doing 5th gen wheels now, even tho they look great to me. i wouldve thought since theyre jus oem wheels they wouldnt be so $$ but i was wrong. im going for kosei or something so i can actually feel the power in acceleration.
thanks for changing my mind guys
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
