Replace Nissan Blower Motor With Siemens?
Old Mar 22, 2002 | 05:25 AM
Minh's Avatar
Hello;
I'm having the somewhat common problem of noise coming out of my heat/ac fan at low speeds. I have brought it into the dealership for the TSB fix, but that didn't do anything to alleviate the noise.
I'm looking into replacing the blower motor completely and instead of
replacing it with another Nissan blower motor someone has suggested that I try an OEM blower motor from SIEMENS Part No. PM2709 (Find one at http://http://www.autozone.com/), it sells for 67.99.
I was wondering if anyone has done this before, if so, is it an exact fit (Position of the screws, electrical connector, etc.), does it work well, do you need any special tools to install it or is it a straight up switch with the Nissan one?
Any help appreciated.
Old Mar 22, 2002 | 06:42 AM
FLO_BOY's Avatar
Re: Replace Nissan Blower Motor With Siemens?
Is the TSB fix free? Just curious.
Old Mar 22, 2002 | 01:16 PM
Minh's Avatar
Re: Re: Replace Nissan Blower Motor With Siemens?
No, the TSB isn't free.
The "fix" is nothing more then a small piece of foam/plastic that goes over the motor to muffle the sound. Doesn't work.
The component itself is about 6$, depending on if you do it yourself or have them do it, it will either cost 6$ or ~50$.
vingodine
45
May 21, 2016 12:46 PM
doobadoo
Aug 15, 2015 06:43 PM
kirkhilles
Aug 8, 2015 10:53 AM
silver_i35
Aug 3, 2015 11:20 PM
