? on 300ZX brake upgrade.
Old Mar 28, 2002 | 06:04 AM
Aaron's Avatar
Langley AFB Sux
I hear you need 17" rims for this. Why? 300zx rims are 16" as well. I think the only clearance problem is with the new caliper hitting the inside of the wheel......where it mounts to the rotor. If thats the case wheel spacers and perhaps some longer studs should do the trick right?
Aaron
Anyone have a pic of a max w/ this done?
Old Mar 28, 2002 | 08:11 AM
SuDZ's Avatar
Does it have something to do with offset?
SuDZ
Old Mar 28, 2002 | 08:50 AM
Aaron's Avatar
Langley AFB Sux
Im thinking so
SuDZ
people say the caliper is wider......no kidding right.....but the overall diameter of the setup cant be that much bigger to need 17 inchers...i think they just wont clear the hub on the wheel without a bigger offset....ie wheel spacers......
Old Mar 28, 2002 | 08:56 AM
psu max's Avatar
Re: ? on 300ZX brake upgrade.
na 300zx 16x7.5 will work as well. along with 16x7.5 koseis basically anything that fits a 90-96 na 300zx would work ... the diameter isnt as important as offset and spoke design.
they will fit under something smaller than 17s, the rotor will only be ~11" . so you dont have to worry about overall diameters (i think someone said it could fit under 15s) you should be more concerned with the spoke design not clearing the calipers
Old Mar 28, 2002 | 09:00 AM
Aaron's Avatar
Langley AFB Sux
Re: Re: ? on 300ZX brake upgrade.
I have 98 SE wheels now....i was thinking they would clear w/spacers...
Old Mar 28, 2002 | 09:08 AM
psu max's Avatar
http://forums.maxima.org/showthread....ighlight=300zx
i think ppl are having their doubts about 99 se's clearign with spacers. the sad thing is, you won't know if they'll clear with spacers or not until you get the Z brakes on and put on you 98's
right now, im looking into getting some used Z rims and then maybe doing the swap
Old Mar 28, 2002 | 09:14 AM
Aaron's Avatar
Langley AFB Sux
Only one way to find out. Im gonna try to round up the parts when i get back from UAE........
Old Mar 28, 2002 | 09:17 AM
psu max's Avatar
good luck and let us kno how it goes
Old Mar 28, 2002 | 09:33 AM
Aaron's Avatar
Langley AFB Sux
Will do
See you guys in a couple o months
Aaron
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
